我是新手 刚学接触这个没多久
这个是FC20和fc21的两个模块 看了半天硬是没明白什么意思
求大侠帮忙解读下 越详细越好
小弟现在这谢谢啦
FC20
CALL "DPRD_DAT" SFC14 --Read Consistent Date of a standard DP slave
LADDR :="牵引辊".LADDR DB12.DBW96 --节点地址
RET_VAL:="牵引辊".WR_RET DB12.DBW98
RECORD :=P#DB12.DBX84.0 BYTE 12
A DB12.DBX 84.4
= DBX 1.4
AN DBX 85.3
= DBX 1.0
A DBX 95.6
= DBX 1.1 //外部条件满足
AN DBX 98.7
= DBX 1.2 //通讯故障
FC21
CALL "DPWR_DAT" SFC14 --Write Consistent Date of a standard DP slave
RECORD :=P#DB12.DBX72.0 BYTE 12
