Normally 200kw VSD is equipted with power fuses itself. The circuit breaker is use to protect the cable to VSD. The circuit breaker is also the second protection to VSD and down stream electrical calbes and fan motor. The circuit current is the measure of cutoff capaicity of the circuit breaker when circuit breaker is under short circuit current. The higher the better. I recommand to use 135kA. If the price is not big issue.
why do you write in English? practicing English?
It's not the case that "the higher the better" if we consider the ecnomy factor.
but thank you anyway.
