功率控制
功率控制产品包括理想二极管、PowerPath 控制器、MOSFET 驱动器、桥式驱动器和其他非稳压器型电源应用。
功率控制ProductFunction Comments Extended Temp Packages Featured Date Added Price 1k* LT1158Half Bridge DriverOn-Chip Charge Pump, Drives All N-Channel MOSFETsISO-16, N-16no1984/1/1$3.30 (LT1158CN#PBF)LT1160Half Bridge DriverInput UV Lockout, High Side Gate Drive UV LockoutISO-14, N-14yes1984/1/1$2.80 (LT1160CN)LT1161Quad High Side DriverShort Circuit Protection with Restart Timers. single driver:LT1910C, ISO-20, N-20no1984/1/1$3.20 (LT1161CN)LT1162Dual Half Bridge DriverInput UV Lockout, High Side Gate Drive UV LockoutISO-24, N-24yes1984/1/1$5.05 (LT1162CSW)LT1241Pulse Width ModulatorsHigh Speed Current Mode Pulse Width ModulatorsC, IDIP-8, SO-8no1984/1/1$1.95 (LT1241CN8)LT1242Pulse Width ModulatorsHigh Speed Current Mode Pulse Width ModulatorsC, IDIP-8, SO-8no1984/1/1$1.95 (LT1242CN8)LT1243Pulse Width ModulatorsHigh Speed Current Mode Pulse Width ModulatorsC, IDIP-8, SO-8no1984/1/1$1.95 (LT1243CN8)LT1244Pulse Width ModulatorsHigh Speed Current Mode Pulse Width ModulatorsC, I, MDIP-8, SO-8, CERDIPno1984/1/1$1.95 (LT1244CN8)LT1245Pulse Width ModulatorsHigh Speed Current Mode Pulse Width ModulatorsC, I, MDIP-8, SO-8, CERDIPno1984/1/1$1.95 (LT1245CN8)LT1246Pulse Width Modulators1MHz Off-Line Current Mode PWM and DC/DC ConverterCDIP-8, SO-8no1984/1/1$2.15 (LT1246CN8)LT1247Pulse Width Modulators1MHz Off-Line Current Mode PWM and DC/DC ConverterCDIP-8, SO-8no1984/1/1$2.10 (LT1247CN8)LT1248Power Factor ControllerPower Factor ControllerCSO-16, N-16yes1984/1/1$3.60 (LT1248CN)LT1249Power Factor ControllerPower Factor ControllerCSO-16, N-16no1984/1/1$3.25 (LT1249CN8)LT1313Dual Vpp Driver/RegulatorUseful with overwindingCSO-16no1984/1/1$3.10 (LT1313CS)LT1336Half Bridge Driver0% to 100% Duty Cycle Operation for Servo Motor DriveISO-16no1984/1/1$3.00 (LT1336CN#PBF)LT1509Power Factor ControllerPower Factor and PWM ControllerCSO-20, N-20yes1984/1/1$3.95 (LT1509CN)LT1910Protected High Side MOSFET Driver-15V to 60V transient protected. quad driver: LT1161E, ISO-8yes1984/1/1$2.05 (LT1910ES8)LT4356-1_-2Overvoltage Protection Regulator and Inrush LimiterSurge Stopper, Auto Retry, Shutdown reduces quiescent current to 7uAC, I, HDFN-12, MS-10, SO-16no2007/7/2$1.98 (LT4356CDE-1)LT4356-1_-2Overvoltage Protection Regulator and Inrush LimiterSurge Stopper, Auto Retry, Shutdown reduces quiescent current to 60uA, keeps the reference and auxiliary amplifier functioningC, I, HDFN-12, SO-16no########$1.98 (LT4356CDE-1)LT4356-3Overvoltage Protection Regulator and Inrush LimiterSurge Stopper with Fault Latchoff, Shutdown reduces quiescent current to 7uAC, I, H, MPDFN-12, MS-10, SO-16no########$1.98 (LT4356CDE-1)LT4356MPSurge StopperSurge Stopper, Guaranteed -55掳C to 125掳C Operation, Shutdown reduces quiescent current to 7uAMPMS-10, SO-16no########$1.98 (LT4356CDE-1)LT4356MPSurge StopperSurge Stopper, Guaranteed -55掳C to 125掳C Operation, Shutdown reduces quiescent current to 60uAMPMS-10, SO-16no########$1.98 (LT4356CDE-1)LT4363Surge StopperHigh Voltage Surge Stopper with Current LimitC, IDFN-12, MS-12, SO-16no########$2.48 (LT4363CDE-1#PBF)LTC1153Electronic Circuit BreakerProgrammable Trip, Reset, Current LevelISO-8, N-8no1984/1/1$2.05 (LTC1153CN8)LTC1154Single High Side MOSFET DriverShort Circuit ProtectionC, HSO-8, N-8yes1984/1/1$1.80 (LTC1154CN8)LTC1155Dual High Side MOSFET DriverDual Version of LTC1154C, ISO-8, N-8no1984/1/1$2.90 (LTC1155CN8)LTC1156Quad High Side DriverQuad Version of LTC1154C, ISO-16, N-8no1984/1/1$4.75 (LTC1156CN)LTC1157Dual 3.3V High Side Driver3.3V or 5V Operation, Low CostCSO-8, N-8no1984/1/1$2.45 (LTC1157CN8)LTC1163Triple High Side DriverGood for 2 Cell Battery ManagementCSO-8, N-8no1984/1/1$2.70 (LTC1163CN8)LTC1165Triple High Side DriverOperates from 2 Cells, P-Channel ReplacementCSO-8, N-8no1984/1/1$2.70 (LTC1165CN8)LTC1255Dual High Side MOSFET DriverGood for 24V Automotive OperationISO-8, N-8no1984/1/1$2.90 (LTC1255CN8)LTC1314VPP + VCC Switch MatrixInternal Drivers for Vcc MOSFETsCSO-14no1984/1/1$2.30 (LTC1314CS)LTC1315Dual VPP + VCC Switch MatrixInternal Drivers for Vcc MOSFETsCG24no1984/1/1$3.30 (LTC1315CG)LTC14705V/3.3V Vcc Switch MatrixFully Integrated VCC Switch with SafeSlot ProtectionCSO-8yes1984/1/1$2.45 (LTC1470CS8)LTC1471Dual 5V/3.3V VPP MatrixFully Integrated VCC Switch with SafeSlot ProtectionCSO-16no1984/1/1$4.10 (LTC1471CS)LTC1472Single VPP + VCC MatrixSwitch Matrix with SafeSlot ProtectionCSO-16yes1984/1/1$3.40 (LTC1472CS)LTC1473PowerPath ControllerDual, High Gate DriveC, ISSOP-16no1984/1/1$3.55 (LTC1473CGN)LTC1473LPowerPath ControllerPower path management for multiple DC sources. 3.3V to 10V input. all N-Channel MOSFETs for low lossCSSOP-16no1984/1/1$3.55 (LTC1473CGN)LTC1477High Side SwitchGood for Subsystem Power SwitchesCSO-8, SO-16no1984/1/1$3.35 (LTC1477CS8)LTC1478High Side SwitchGood for Subsystem Power SwitchesCSO-8, SO-16no1984/1/1$5.30 (LTC1478CS)LTC1479PowerPathTriple PowerPath Controller for Dual Battery Systems and AC/DCC, ISSOP-36no1984/1/1$7.05 (LTC1479CG)LTC1623Dual SMBus Switch DriverControl Up to 16 Peripherals on Same BusIMS-8, SO-8no1984/1/1$1.85 (LTC1623CMS8)LTC1693Dual P-Channel MOSFET DriverTwo noninverting drivers.1.5A peak output currentC, ISO-8no1984/1/1$1.60 (LTC1693-1CS8)LTC1693-5Dual P-Channel MOSFET Driver1.5A peak output currentCMS-8no1984/1/1$1.60 (LTC1693-1CS8)LTC1695SMBus/I虏C Fan Speed Controller in SOT-23CSOT-23no1984/1/1$1.51 (LTC1695CS5#TR)LTC1696Overvoltage Protection ControllerMonitors Two Output Voltages from 0.8V to 24V. Gate drive for SCR crowbar or external N-channel FETESOT-23no1984/1/1$1.78 (LTC1696ES6#TRM)LTC1699SMBus VID ProgrammerEMS-8, SSOP-16no1984/1/1$2.15 (LTC1699EMS8-80)LTC1699SMBus VID ProgrammerEMS-8, SSOP-16no2010/2/2$2.15 (LTC1699EMS8-80)LTC1699SMBus VID ProgrammerEMS-8, SSOP-16no2010/2/2$2.15 (LTC1699EMS8-80)LTC1706-19VID ProgrammerE, IMS-10no1984/1/1$1.95 (LTC1706CS8-19)LTC1706-61VID ProgrammerE, IMS-10no1984/1/1$1.95 (LTC1706CS8-19)LTC1706-635-Bit VID Voltage Programmer for Sun CPUsEMS-10no1984/1/1$1.95 (LTC1706CS8-19)LTC1706-815-Bit Desktop VID Voltage ProgrammerE, IMS-10no1984/1/1$1.95 (LTC1706CS8-19)LTC1706-82VID ProgrammerE, IMS-10no1984/1/1$1.95 (LTC1706CS8-19)LTC1706-85VID ProgrammerE, IMS-10no1984/1/1$1.95 (LTC1706CS8-19)LTC1710Dual SMBus SwitchesControl Up to 6 Peripherals on Same BusIMS-8, SO-8no1984/1/1$3.00 (LTC1710CMS8)LTC1840Fan speed controller with two tach inputs and four general purpose I/OC, ISSOP-16yes1984/1/1$2.75 (LTC1840CGN)LTC1923Thermoelectric Cooler. Full Bridge ControllerHigh efficiency, low noise topologyE5x5 QFN, SSOP28yes1984/1/1$18.17 (LTC1923EGN)LTC1981N-Channel MOSFET DriverUltralow power. smallESOT-23no1984/1/1$1.26 (LTC1981ES5#TR)LTC1982Dual P-Channel MOSFET DriverUltralow power. smallESOT-23no1984/1/1$1.50 (LTC1982ES6#TR)LTC2952PowerPath Controller, Push ButtonPush Button PowerPath Controller with SupervisorC, ITSSOP-20, QFN-20no1984/1/1$2.95 (LTC2952CF)LTC3226PowerPath Controller, Supercapacitor Charger2-Cell Supercapacitor Charger with Backup PowerPath ControllerE, IQFN-16no2011/7/8$2.67 (LTC3226EUD#PBF)LTC4213Electronic Circuit BreakerNo RSENSE Electronic Circuit BreakerC, IDFN-8no1984/1/1$1.56 (LTC4213CDDB#TR)LTC4225Ideal Diode, Hot SwapDual Ideal Diode and Hot Swap Controller, Latch Off After FaultC, IQFN-24, SSOP-24no########$3.59 (LTC4225CGN-1#PBF)LTC4225Ideal Diode, Hot SwapDual Ideal Diode and Hot Swap Controller, Retry After FaultC, IQFN-24, SSOP-24no########$3.59 (LTC4225CGN-1#PBF)LTC4227Ideal Diode, Hot SwapDual Ideal Diode and Single Hot Swap Controller, Latch Off After FaultC, IQFN-20, SSOP-16no########$3.41 (LTC4227CGN-1#PBF)LTC4227Ideal Diode, Hot SwapDual Ideal Diode and Single Hot Swap Controller, Automatic Retry After FaultC, IQFN-20, SSOP-16no########$3.41 (LTC4227CGN-1#PBF)LTC4228Ideal Diode, Hot SwapDual Ideal Diode and Hot Swap Controller, Latch Off After FaultC, IQFN-28, SSOP-28yes########$3.59 (LTC4228CGN-1#PBF)LTC4228Ideal Diode, Hot SwapDual Ideal Diode and Hot Swap Controller, Retry After FaultC, IQFN-28, SSOP-28yes########$3.59 (LTC4228CGN-1#PBF)LTC4352Ideal DiodeLow Voltage Ideal Diode Controller with MonitoringC, I, HMS-12, DFN-12no########$2.50 (LTC4352CDD#PBF)LTC4353Ideal DiodeDual Low Voltage Ideal Diode ControllerC, IMS-16, DFN-16yes########$3.45 (LTC4353CDE#PBF)LTC4354Ideal DiodeDual Channel, 1碌s Turn-off TimeC, IDFN-8, SO-8no1984/1/1$2.11 (LTC4354CDDB#TR)LTC4355Ideal DiodePositive High Voltage Dual Ideal Diode-OR with Input Supply and Fuse MonitorsC, IDFN-14, SSOP-16no########$2.50 (LTC4355CDE#PBF)LTC4357Ideal DiodePositive High Voltage Ideal Diode ControllerC, I, H, MPDFN-6, MS-8no########$1.75 (LTC4357CDCB#TRMPBF)LTC4358Ideal Diode5A Ideal DiodeC, IDFN-14, TSSOP-14yes########$2.10 (LTC4358CDE#PBF)LTC4359Ideal DiodeIdeal Diode Controller with Reverse Input ProtectionC, I, HDFN-6, MS-8yes########$2.15 (LTC4359CDCB#TRMPBF)LTC4360Overvoltage Protection ControllerOvervoltage/Overcurrent Protection Controller, Low Current ShutdownC, ISC-70no########$1.20 (LTC4360CSC8-1#TRMPBF)LTC4360Overvoltage Protection ControllerOvervoltage/Overcurrent Protection Controller, Reverse Voltage ProtectionC, ISC-70no########$1.20 (LTC4360CSC8-1#TRMPBF)LTC4361Overvoltage/Overcurrent Protection ControllerOvervoltage/Overcurrent Protection Controller, Latchoff after FaultC, I, HSOT-23, DFN-8no########$1.45 (LTC4361CDC-1#TRMPBF)LTC4361Overvoltage/Overcurrent Protection ControllerOvervoltage/Overcurrent Protection Controller, Auto Retry after FaultC, I, HSOT-23, DFN-8no########$1.45 (LTC4361CDC-1#TRMPBF)LTC4362Overvoltage/Overcurrent Protection Controller1.2A Overvoltage/Overcurrent Protector, Latchoff after FaultC, IDFN-8no########$1.65 (LTC4362CDCB-1#TRMPBF)LTC4362Overvoltage/Overcurrent Protection Controller1.2A Overvoltage/Overcurrent Protector, Auto Retry after FaultC, IDFN-8no########$1.65 (LTC4362CDCB-1#TRMPBF)LTC4364Ideal Diode, Surge StopperSurge Stopper with Ideal DiodeC, I, HDFN-14, MS-16, SO-16yes########$3.45 (LTC4364CDE-1#PBF)LTC4364Ideal Diode, Surge StopperSurge Stopper with Ideal Diode, 0.1% Retry Duty Cycle During FaultsC, I, HDFN-14, MS-16, SO-16yes########$3.45 (LTC4364CDE-1#PBF)LTC4365UV/OV & Reverse Supply Protection ControllerControls Dual N-Channel MOSFET, Fault Status PinC, I, HDFN-8, SOT-23no########$1.49 (LTC4365CDDB#TRPBF)LTC4366Surge StopperHigh Voltage Surge Stopper, Latch OffC, I, H, MPSOT-23, DFN-8yes########$2.70 (LTC4366CDDB-1#TRMPBF)LTC4366Surge StopperHigh Voltage Surge Stopper, Auto RetryC, I, H, MPSOT-23, DFN-8yes########$2.70 (LTC4366CDDB-1#TRMPBF)LTC4370Ideal DiodeTwo-Supply Diode-OR Current Balancing ControllerC, IMS-16, DFN-16yes########$4.95 (LTC4370CDE#PBF)LTC4410USB Power ManagerAllows faster charging from USB port and complies with USB spec.EThinSOTno1984/1/1$1.26 (LTC4410ES6#TR)LTC4411Ideal DiodeIntegrated switch: Replaces power supply ORESOT-23no1984/1/1$1.66 (LTC4411ES5#TR)LTC4412PowerPath ControllerReplaces power supply ORE, ISOT-23no1984/1/1$1.36 (LTC4412ES6#TR)LTC4412HVPowerPath ControllerRugged version of the LTC4412: Vin up to 36V. Guaranteed operation from -40degC to 125degCISOT-23yes1984/1/1$1.36 (LTC4412ES6#TR)LTC4413Ideal DiodeDual 2.6A, 2.5V to 5.5V, Ideal Diodes in 3mm 脳 3mm DFNEDFN-10no1984/1/1$2.15 (LTC4413EDD)LTC4413-1_-2Ideal DiodeDual 2.6A, 2.5V to 5.5V Fast Ideal Diodes in a 3mm x 3mm DFNEDFN-10no1984/1/1$2.15 (LTC4413EDD)LTC4413-1_-2Ideal DiodeDual 2.6A, 2.5V to 5.5V Fast Ideal Diodes in a 3mm x 3mm DFN, Overvoltage Protection Sensor with Drive Output for an External P-Channel MOSFETEDFN-10no########$2.15 (LTC4413EDD)LTC4414PowerPath36V, Low Loss PowerPath Controller for Large PFETsE, IMS-8no1984/1/1$1.85 (LTC4414EMS8)LTC4415Ideal DiodeDual 4A Ideal Diodes with Adjustable Current Limit, Imon Outputs, Overcurrent Warning, Thermal WarningE, IMS-16, DFN-16yes########$2.95 (LTC4415EDHC#PBF)LTC4416PowerPath Controller36V, Low Loss Dual PowerPath Controllers for Large PFETsE, IMS-10yes1984/1/1$2.45 (LTC4416EMS#PBF)LTC4417PowerPath ControllerPrioritized PowerPath ControllerC, I, HSSOP-24, QFN-24yes########$3.15 (LTC4417CGN#PBF)LTC4440High Speed, High Voltage High Side MOSFET Driver1.5ohm pull-down, 2.4A pull-up driversEMS-8, SOT-23yes1984/1/1$1.75 (LTC4440EMS8E)LTC4440-5High Speed, High Voltage High Side MOSFET DriverOptimized for Logic Level FETs. 1.85ohm pull-down, 1.1A pull-up driversEMSOP-8E, SOT-23yes1984/1/1$1.75 (LTC4440EMS8E)LTC4441FET Driver6A Peak Output Current, Adjustable Blanking Time for MOSFETs Current Sense SignalE, I, MPMS-10no1984/1/1$1.80 (LTC4441EMSE)LTC4441FET Driver6A Peak Output CurrentE, I, MPSO-8no########$1.80 (LTC4441EMSE)LTC4442N-Channel MOSFET DriverHigh Speed Synchronous N-Channel MOSFET Drivers, 3.2V Undervoltage Lockout ThresholdE, IMS-8yes########$1.25 (LTC4442EMS8E#PBF)LTC4442N-Channel MOSFET DriverHigh Speed Synchronous N-Channel MOSFET Drivers, 6.2V Undervoltage Lockout ThresholdE, IMS-8yes########$1.25 (LTC4442EMS8E#PBF)LTC4444FET DriverHigh Voltage Synchronous N-Channel MOSFET DriverE, I, H, MPMS-8no########$1.69 (LTC4444EMS8E#PBF)LTC4444-5N-Channel MOSFET DriverHigh Voltage Synchronous N-Channel MOSFET DriverE, I, H, MPMS-8no########$1.69 (LTC4444EMS8E#PBF)LTC4446N-Channel MOSFET DriverHigh Voltage High Side / Low Side N-Channel MOSFET DriverE, IMS-8no########$1.69 (LTC4446EMS8E#PBF)LTC4449N-Channel MOSFET DriverHigh Speed Synchronous N-Channel MOSFET DriverE, IDFN-8no########$1.30 (LTC4449EDCB#TRMPBF)
