首页 安防智能
主题:线性稳压器
点击:709 回复:0
 线性稳压器http://www.bdtic.com/images/ChanPinGaiShu.gif概述电子档:低压降低压降标准负电压稳压器标准负电压稳压器标准正电压稳压器标准正电压稳压器超低压降超低压降
[/URL][/URL][/URL]低压降型号概述KD1084AXX185 A low drop positive voltage regulator adjustable and fixedL4941Very low drop 1A regulatorLD1084XX5A LOW DROP ADJUSTABLE POSITIVE VOLTAGE REGULATORLD1085CXX3A LOW DROP ADJUSTABLE POSITIVE VOLTAGE REGULATORLD1085XX3A LOW DROP ADJUSTABLE POSITIVE VOLTAGE REGULATORLD1085XX183A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1085XX253A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1085XX333A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1085XX503A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1086XX1.5A LOW DROP ADJUSTABLE POSITIVE VOLTAGE REGULATORLD1086XX121.5A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1086XX181.5A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1086XX251.5A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1086XX331.5A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1086XX501.5A LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117AXXLOW DROP ADJUSTABLE POSITIVE VOLTAGE REGULATORLD1117AXX12LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117AXX18LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117AXX33LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XXLOW DROP ADJUSTABLE POSITIVE VOLTAGE REGULATORLD1117XX12Fixed low drop positive voltage regulatorLD1117XX12CFixed low drop positive voltage regulatorLD1117XX18LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XX18CLOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XX25LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XX25CLOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XX33LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XX33CLOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XX50LOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XX50CLOW DROP FIXED POSITIVE VOLTAGE REGULATORLD1117XXCLOW DROP ADJUSTABLE POSITIVE VOLTAGE REGULATORLK112SXX18LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112SXX33LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112SXX50LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112XX15LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112XX18LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112XX25LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112XX33LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112XX50LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112XX60LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONLK112XX80LOW NOISE LOW DROP VOLTAGE REGULATOR WITH SHUTDOWN FUNCTIONST1L02XX18Very low quiescent BiCMOS voltage regulatorST1L02XX25Very low quiescent BiCMOS voltage regulatorST1L02XX33Very low quiescent BiCMOS voltage regulatorST1L04LOW QUIESCENT CURRENT VOLTAGE REGULATORST1L05Very low quiescent BiCMOS voltage regulatorST1L05AVery low quiescent BiCMOS voltage regulatorST1L05BVery low quiescent BiCMOS voltage regulatorST1L05CVery low quiescent BiCMOS voltage regulatorST1L05DVery low quiescent BiCMOS voltage regulatorST2L05-3300DUAL VOLTAGE REGULATORST715XXHigh input voltage - 85 mA LDO linear regulatorST715XX25High input voltage - 85 mA LDO linear regulatorST715XX33High input voltage - 85 mA LDO linear regulator
[/URL][/URL][/URL]标准负电压稳压器型号概述L7905AC2% NEGATIVE VOLTAGE REGULATORL7905CNEGATIVE VOLTAGE REGULATORL7908CNEGATIVE VOLTAGE REGULATORL7912AC2% NEGATIVE VOLTAGE REGULATORL7912CNEGATIVE VOLTAGE REGULATORL7915AC2% NEGATIVE VOLTAGE REGULATORL7915CNEGATIVE VOLTAGE REGULATORL79L05ABNEGATIVE VOLTAGE REGULATORL79L05ACNEGATIVE VOLTAGE REGULATORL79L08ACNEGATIVE VOLTAGE REGULATORL79L12ACNEGATIVE VOLTAGE REGULATORL79L15ABNEGATIVE VOLTAGE REGULATORL79L15ACNEGATIVE VOLTAGE REGULATORLM137THREE-TERMINAL ADJUSTABLE NEGATIVE VOLTAGE REGULATORLM337THREE-TERMINAL ADJUSTABLE NEGATIVE VOLTAGE REGULATOR
[/URL][/URL][/URL]标准正电压稳压器型号概述L200Adjustable voltage and current regulatorL7805Positive voltage regulatorsL7805ABPrecision 1 A regulatorsL7805ACPrecision 1 A regulatorsL7805CPositive voltage regulatorsL7806ABPrecision 1 A regulatorsL7806ACPrecision 1 A regulatorsL7806CPositive voltage regulatorsL7808ABPrecision 1 A regulatorsL7808ACPrecision 1 A regulatorsL7808CPositive voltage regulatorsL7809ABPrecision 1 A regulatorsL7809ACPrecision 1 A regulatorsL7809CPositive voltage regulatorsL7812ABPrecision 1 A regulatorsL7812ACPrecision 1 A regulatorsL7812CPositive voltage regulatorsL7815ABPrecision 1 A regulatorsL7815ACPrecision 1 A regulatorsL7815CPositive voltage regulatorsL7818CPositive voltage regulatorsL7824ABPrecision 1 A regulatorsL7824ACPrecision 1 A regulatorsL7824CPositive voltage regulatorsL7885CPositive voltage regulatorsL78L05ABPositive voltage regulatorsL78L05ACPositive voltage regulatorsL78L05CPositive voltage regulatorsL78L06ABPositive voltage regulatorsL78L06ACPositive voltage regulatorsL78L08ABPositive voltage regulatorsL78L08ACPositive voltage regulatorsL78L08CPositive voltage regulatorsL78L09ABPositive voltage regulatorsL78L09ACPositive voltage regulatorsL78L09CPositive voltage regulatorsL78L10ACPositive voltage regulatorsL78L12ABPositive voltage regulatorsL78L12ACPositive voltage regulatorsL78L12CPositive voltage regulatorsL78L15ABPositive voltage regulatorsL78L15ACPositive voltage regulatorsL78L15CPositive voltage regulatorsL78L18ACPositive voltage regulatorsL78L18CPositive voltage regulatorsL78L24ABPositive voltage regulatorsL78L24ACPositive voltage regulatorsL78L24CPositive voltage regulatorsL78L33ABPositive voltage regulatorsL78L33ACPositive voltage regulatorsL78L33CPositive voltage regulatorsL78M05ABPrecision 500 mA regulatorsL78M05ACPrecision 500 mA regulatorsL78M05CPositive voltage regulatorsL78M06ABPrecision 500 mA regulatorsL78M06CPositive voltage regulatorsL78M08ABPrecision 500 mA regulatorsL78M08CPositive voltage regulatorsL78M09ABPrecision 500 mA regulatorsL78M09CPositive voltage regulatorsL78M10ABPrecision 500 mA regulatorsL78M12ABPrecision 500 mA regulatorsL78M12ACPrecision 500 mA regulatorsL78M12CPositive voltage regulatorsL78M15ABPrecision 500 mA regulatorsL78M15CPositive voltage regulatorsL78M24ABPrecision 500 mA regulatorsL78M24ACPrecision 500 mA regulatorsL78M24CPositive voltage regulatorsL78S05C2 A positive voltage regulatorsL78S09C2 A positive voltage regulatorsL78S10C2 A positive voltage regulatorsL78S12C2 A positive voltage regulatorsL78S15C2 A positive voltage regulatorsL78S18C2 A positive voltage regulatorsL78S24C2 A positive voltage regulatorsL78S75C2 A positive voltage regulatorsLM1171.2 V to 37 V adjustable voltage regulatorsLM138Three-terminal 5 A adjustable voltage regulatorsLM2171.2 V to 37 V adjustable voltage regulatorsLM217LLow current 1.2 to 37 V adjustable voltage regulatorLM217MMedium current 1.2 to 37 V adjustable voltage regulatorLM238Three-terminal 5 A adjustable voltage regulatorsLM3171.2 V to 37 V adjustable voltage regulatorsLM317LLow current 1.2 to 37 V adjustable voltage regulatorLM317MMedium current 1.2 to 37 V adjustable voltage regulatorLM323Three-terminal 3 A adjustable voltage regulatorsLM338Three-terminal 5 A adjustable voltage regulatorsLM350Three-terminal 3 A adjustable voltage regulatorsLM723High precision voltage regulatorPB137POSITIVE VOLTAGE REGULATOR FOR BATTERY CHARGER
[/URL][/URL][/URL]超低压降型号概述KF25BVERY LOW DROP VOLTAGE REGULATOR WITH INHIBITKF33BVERY LOW DROP VOLTAGE REGULATOR WITH INHIBITKF50BVERY LOW DROP VOLTAGE REGULATOR WITH INHIBITKF80BVERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931ABXX120VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITL4931ABXX33VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931ABXX35VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931ABXX50VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931ABXX80VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931CXX120VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931CXX27VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931CXX33VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931CXX35VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931CXX50VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4931CXX80VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITL4940XX10VERY LOW DROP 1.5A REGULATORL4940XX12Very low drop 1.5 A regulatorL4940XX5Very low drop 1.5 A regulatorL4940XX85Very low drop 1.5 A regulatorLD1580XX7A VERY LOW DROP VOLTAGE REGULATOR ADJUSTABLE AND FIXEDLD29080XX800 mA fixed and adjustable output very low drop voltage regulatorLD29080XX15800 mA fixed and adjustable output very low drop voltage regulatorLD29080XX180.8 A fixed and adjustable output very low drop voltage regulatorLD29080XX25800 mA fixed and adjustable output very low drop voltage regulatorLD29080XX33800 mA fixed and adjustable output very low drop voltage regulatorLD29080XX50800 mA fixed and adjustable output very low drop voltage regulatorLD29080XX90800 mA fixed and adjustable output very low drop voltage regulatorLD29150XX1.5A, VERY LOW DROP VOLTAGE REGULATORLD29150XX181.5A, VERY LOW DROP VOLTAGE REGULATORLD29150XX251.5A, VERY LOW DROP VOLTAGE REGULATORLD29150XX331.5A, VERY LOW DROP VOLTAGE REGULATORLD29150XX501.5A, VERY LOW DROP VOLTAGE REGULATORLD29300XX3A, VERY LOW DROP VOLTAGE REGULATORLD29300XX183A, VERY LOW DROP VOLTAGE REGULATORLD29300XX333A, VERY LOW DROP VOLTAGE REGULATORLD2979XX30VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITLD2979XX33VERY LOW DROP VOLTAGE REGULATOR WITH INHIBITLD2980ABXX30VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2980ABXX33VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2980ABXX50VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2980CXX18VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2980CXX33VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2980CXX50VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2981ABXX30VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2981ABXX33VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2981ABXX50VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2981CXX25Ultra low drop voltage regulators with inhibit low ESR output capacitors compatibleLD2981CXX30VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2981CXX33VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2981CXX50VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLD2985BXX18VERY LOW DROP AND LOW NOISE VOLTAGE REGULATO WITH INHIBIT FUNCTIONLD2985BXX25VERY LOW DROP AND LOW NOISE VOLTAGE REGULATO WITH INHIBIT FUNCTIONLD2985BXX28VERY LOW DROP AND LOW NOISE VOLTAGE REGULATO WITH INHIBIT FUNCTIONLD2985BXX30VERY LOW DROP AND LOW NOISE VOLTAGE REGULATO WITH INHIBIT FUNCTIONLD2985BXX33VERY LOW DROP AND LOW NOISE VOLTAGE REGULATO WITH INHIBIT FUNCTIONLD2985BXX50VERY LOW DROP AND LOW NOISE VOLTAGE REGULATO WITH INHIBIT FUNCTIONLD39015JXX12150 mA low quiescent current low noise voltage regulatorLD39015JXX15150 mA low quiescent current low noise voltage regulatorLD39015JXX18150 mA low quiescent current low noise voltage regulatorLD39015JXX25150 mA low quiescent current low noise voltage regulatorLD39015JXX28150 mA low quiescent current low noise voltage regulatorLD39015XX08150 mA low quiescent current low noise voltage regulatorLD39015XX10150 mA low quiescent current low noise voltage regulatorLD39015XX12150 mA low quiescent current low noise voltage regulatorLD39015XX125150 mA low quiescent current low noise voltage regulatorLD39015XX15150 mA low quiescent current low noise voltage regulatorLD39015XX18150 mA low quiescent current low noise voltage regulatorLD39015XX25150 mA low quiescent current low noise voltage regulatorLD39015XX33150 mA low quiescent current low noise voltage regulatorLD39030SJXX12300 mA low quiescent current soft-start, low noise voltage regulatorLD39030SJXX126300 mA low quiescent current soft-start, low noise voltage regulatorLD39030SJXX33300 mA low quiescent current soft-start, low noise voltage regulatorLD39050XX500 mA low quiescent current low noise voltage regulatorLD39050XX25500 mA low quiescent current low noise voltage regulatorLD39050XX33500 mA low quiescent current low noise voltage regulatorLD39080XXUltra low drop BICMOS voltage regulatorLD39080XX12Ultra low drop BICMOS voltage regulatorLD39080XX18Ultra low drop BICMOS voltage regulatorLD39080XX25Ultra low drop BICMOS voltage regulatorLD39080XX33Ultra low drop BICMOS voltage regulatorLD39100XX1 A low quiescent current low noise voltage regulatorLD39100XX121A low quiescent current, low noise voltage regulatorLD39100XX251A low quiescent current, low noise voltage regulatorLD39115JXX12150 mA low quiescent current low noise voltage regulatorLD39115JXX15150 mA low quiescent current low noise voltage regulatorLD39115JXX18150 mA low quiescent current low noise voltage regulatorLD39115JXX25150 mA low quiescent current low noise voltage regulatorLD39115JXX28150 mA low quiescent current low noise voltage regulatorLD39115JXX30150 mA low quiescent current low noise voltage regulatorLD39115JXX33150 mA low quiescent current low noise voltage regulatorLD39115SJXX12150 mA low quiescent current low noise voltage regulatorLD39150XXUltra low drop BICMOS voltage regulatorLD39150XX18Ultra low drop BICMOS voltage regulatorLD39150XX25Ultra low drop BICMOS voltage regulatorLD39150XX33Ultra low drop BICMOS voltage regulatorLD39300XXUltra low drop BICMOS voltage regulatorLD39300XX12Ultra low drop BICMOS voltage regulatorLD39300XX18Ultra low drop BICMOS voltage regulatorLD39300XX25Ultra low drop BICMOS voltage regulatorLD39300XX33Ultra low drop BICMOS voltage regulatorLD3980XX08ow drop - Low supply voltage Low ESR capacitor compatibleLD3980XX135ow drop - Low supply voltage Low ESR capacitor compatibleLD3980XX18ow drop - Low supply voltage Low ESR capacitor compatibleLD3985XX122ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX18ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX25ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX26ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX27ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX28Ultra low drop-low noise BiCMOS voltage regulators low ESR capacitors compatibleLD3985XX29ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX30ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX33ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD3985XX47ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATOR LOW ESR CAPACITOR COMPATIBLELD49150XX081.5 VERY LOW DROP VOLTAGE REGULATORLD49150XX101.5 VERY LOW DROP VOLTAGE REGULATORLD49150XX121.5 VERY LOW DROP VOLTAGE REGULATORLD49300XX083A Very low drop for low output voltage regulatorLD49300XX103A Very low drop for low output voltage regulatorLD49300XX123A Very low drop for low output voltage regulatorLD59015XX12150 mA low noise high PSRR linear voltage regulatorLD59015XX15150 mA low noise high PSRR linear voltage regulatorLD59015XX18150 mA low noise high PSRR linear voltage regulatorLD59015XX25150 mA low noise high PSRR linear voltage regulatorLD59015XX30150 mA low noise high PSRR linear voltage regulatorLD59015XX33150 mA low noise high PSRR linear voltage regulatorLDCL015XX150 mA - capless - ultra low drop linear regulatorLDCL015XX33150 mA - capless - ultra low drop linear regulatorLDFM500 mA very low drop voltage regulatorLDFM50500 mA very low drop voltage regulatorLDLN015XX10150 mA - ultra low noise - high PSRR linear voltage regulator ICLDLN015XX12150 mA - ultra low noise - high PSRR linear voltage regulator ICLDLN015XX15150 mA - ultra low noise - high PSRR linear voltage regulator ICLDLN015XX18150 mA - ultra low noise - high PSRR linear voltage regulator ICLDLN015XX28150 mA - ultra low noise - high PSRR linear voltage regulator ICLDLN015XX33150 mA - ultra low noise - high PSRR linear voltage regulator ICLDS3985XX15ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATORS LOW ESR CAPACITORS COMPATIBLELDS3985XX18ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATORS LOW ESR CAPACITORS COMPATIBLELDS3985XX25ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATORS LOW ESR CAPACITORS COMPATIBLELDS3985XX28ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATORS LOW ESR CAPACITORS COMPATIBLELDS3985XX30ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATORS LOW ESR CAPACITORS COMPATIBLELDS3985XX33ULTRA LOW DROP LOW NOISE BICMOS VOLTAGE REGULATORS LOW ESR CAPACITORS COMPATIBLELDS3985XX50Ultra low drop-low noise BiCMOS 300 mA voltage regulator for use with very low ESR output capacitorLE30CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLE33CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLE45CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLE50ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLE50CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLE80CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF120ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF120CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF15ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF18ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF18CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF25ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF25CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF33ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF33CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF50ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF50CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF60ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF60CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF80ABVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF80CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF85CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLF90CVERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLK115XX33VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLK115XX50VERY LOW DROP VOLTAGE REGULATORS WITH INHIBITLM2931AXX33VERY LOW DROP VOLTAGE REGULATOR WITH INHIBIT FUNCTIONLM2931AXX50VERY LOW DROP VOLTAGE REGULATOR WITH INHIBIT FUNCTIONLM2931XXVERY LOW DROP VOLTAGE REGULATOR WITH INHIBIT FUNCTIONSTLQ015XX12150 mA - ultra low quiescent current linear voltage regulatorSTLQ015XX15150 mA - ultra low quiescent current linear voltage regulatorSTLQ015XX18150 mA - ultra low quiescent current linear voltage regulatorSTLQ015XX25150 mA - ultra low quiescent current linear voltage regulatorSTLQ015XX28150 mA - ultra low quiescent current linear voltage regulatorSTLQ015XX30150 mA - ultra low quiescent current linear voltage regulatorSTLQ015XX31150 mA - ultra low quiescent current linear voltage regulatorSTLQ015XX33150 mA - ultra low quiescent current linear voltage regulatorSTLQ5050mA, 3uA Supply current low drop linear regulatorSTLQ50XX1850mA, 3uA Supply current low drop linear regulatorSTLQ50XX2550mA, 3uA Supply current low drop linear regulatorSTLQ50XX3350 mA, 3 nA supply current low drop linear regulatorSTLQ50XX5050mA, 3uA Supply current low drop linear regulator[/URL]
13-07-23 13:44
