首页 工控贴图
主题:这是啥控制器啊
点击:1445 回复:13
今天在群里看到有人发了个图,右边那是西门子,可左边那红色的是啥控制器啊?
美国红狮 Redlion 模块化控制器
独立串口配置,方便和其他设备集成
10 T/100 TX以太网口,支持网络通讯
最多可支持16个MC 系列模块
支持通过Crimson 2.0软件进行配置(Crimson 2.0向下兼容 Crimson 1.0)
你看下具体型号是什么
13-05-30 21:54
原来红狮还做控制器呀!
13-05-31 09:01
紅狮也  进驻中国了?
13-05-31 12:29
2楼此言正确
13-05-31 14:01
红狮子那个是控制器啊
13-06-03 15:49
引用 思南 在 2013/6/3 15:49:14 发言【内容省略】
同问!!!
13-06-03 16:16
微博网友回复:
原来是红狮的东西:
:: Modular Controller ::
Red Lion’s Modular Controller series offers a cost effective solution to integrating multi-zone PID control, data acquisition and I/O into your PC, DCS or PLC control system. You can drag and drop controller data to PLC registers in seconds using point-and-click data mapping from an extensive menu of built-in serial and Ethernet drivers. No tedious PLC code to write.
Instantly Ethernet-enable your PLC for free! Not only are programming costs slashed, you can eliminate costly add-on I/O and analog cards and solve applications simply using an inexpensive brick PLC.
The high-density DIN rail design saves panel space and eliminates cutouts. All modules can be hot-swapped -- the master automatically programs a replaced module.
CSOUT 4-Channel Analog Output Module
CSMSTR LE/SX/GT Enhanced Modular Controller Master
CSMSTRV2 Modular Controller Series Master
CSDIO Digital I/O Module with Logic Engine
CSINI8 / CSINV8 Analog Input Modules
CSMSTRZR Enhanced Modular Controller Master
CSPID PID Control Modules
CSSG Strain Gage Module
CSTC8 / CSRTD6 Temperature Input Modules
13-06-05 09:34
 没看到过这个的模块 !
14-11-18 20:49
上一页下一页
