首页 电脑编程
主题:问个关于MODBUS通讯的接受问题
点击:1958 回复:4
现在我数据能传给下位机了,下位机也能收到并给回答了,但是上位机收到的数据由于ascⅡ的限制只能传128前的数据,以后的数据80开始我收到的会溢出显示3F。。还有就是我收到的CRC也是这样,而且要是CRC大于80的话,会显示00,程序会有个停顿,不知道为什么。。。
05-04-08 10:34
请发EMAIL给我
summer_sunjie@sina.com
部分源代码在这里
Private Sub Hexsent()                           '·¢ËÍ×Ó³ÌÐò
       Stxt.Text = txtSend + RTUCRC
       Dim hexchrlen%, hexchr As String, hexcyc%, hexmid As String
       Dim i, j As Integer
              hexchrlen = Len(Stxt)
              For hexcyc = 1 To hexchrlen          'hexcyc=1to16     ¼ì²é·¢Ë͵ÄÊýÖµÊÇ·ñºÏÊÊ
              hexchr = Mid(Stxt, hexcyc, 1)
              If InStr("0123456789ABCDEFabcdef", hexchr) = 0 Then
                    MsgBox "ÎÞЧµÄÊýÖµ£¬ÇëÖØÐÂÊäÈë", , "´íÎóÐÅÏ¢"
                    Exit Sub
               End If
              Next
              ReDim outbyte(1 To hexchrlen / 2) As Byte
              For i = 1 To hexchrlen / 2
                    hexcyc = 2 * i - 1
                    hexchr = Mid(Stxt, hexcyc, 2)
                    hexmid = CStr(hexchr)
                    outbyte(i) = Val("&H" + hexmid)
                Next i
             ctrMSComm.Output = outbyte()
   End Sub
'´Ë´¦Ìí¼Ó´¦Àí½ÓÊյĴúÂë
              ' hexstring = ctrMSComm.Input
              ' i = Len(hexstring)
              ' For j = 1 To i
              ' hexchr = Mid(hexstring, j, 1)
              ' If Hex(Asc(hexchr)) < 16 Then               'Èç¹ûhexchr(asc(chr)>128  Òç³ö Ϊ3F
              ' txtReceive.Text = txtReceive.Text & "0" & Hex(Asc(hexchr)) & " "
              ' Else
              ' txtReceive.Text = txtReceive.Text & Hex(Asc(hexchr)) & " "
              ' End If
              ''txtReceive.Text = txtReceive.Text & ctrMSComm.Input & CStr(Chr(13)) & CStr(Chr(10))
              ' Next j
05-04-08 10:36
80H->1000,0000B 最高位是符号位
05-04-10 15:18
请教怎么解决呢?
05-04-11 09:30
thdy345@163.com
很想得到您的源代码,非常感谢
05-09-20 16:55
