首页 电脑编程
主题:九九乘法的九种输出形式
点击:706 回复:2
九九乘法,比较经典的例子。看起来似乎很简单,关键是理解算法,以及如何实现算法。
老规矩,老鸟飘过,分享给需要学习的朋友.....
1.矩形输出
http://blog.gkong.com/uploadfile5/201344153354461.gif
Sub Main()
       Dim a As Integer
       Dim b As Integer
       For a = 1 To 9
           For b = 1 To 9
               Console.Write("{0}*{1}={2}{3}", a, b, a * b, vbTab)
           Next
           Console.WriteLine()
       Next
       Console.WriteLine("~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~")
End Sub
2.三角形输出 I
http://blog.gkong.com/uploadfile5/201344153631247.gif
sub main()
Dim i As Integer
       Dim j As Integer
       For i = 1 To 9
           For j = 1 To 9
               If i > j Then
                   Console.Write("{0}*{1}={2}{3}", i, j, i * j, vbTab)
               End If
               If i = j Then
                   Console.WriteLine("{0}*{1}={2}", i, j, i * j)
               End If
           Next
       Next
End sub
3.三角形输出 II
http://blog.gkong.com/uploadfile5/201344153847880.gif
Sub main()
Dim m As Integer
       Dim n As Integer
       For m = 1 To 9
           For n = 1 To 9
               If m <= n Then
                   Console.Write("{0}*{1}={2}{3}", m, n, m * n, vbTab)
               End If
           Next
           Console.WriteLine()
       Next
End Sub
4.三角形输出 III
http://blog.gkong.com/uploadfile5/201344154142938.gif
Sub main()
Console.WriteLine("01234567891012345678901234567890123456789~~~~~~~~~~~~~~~~~~~~~~~~~~~~~")
       Dim x As Integer, y As Integer, p As Integer = 0
       For x = 1 To 9
           For y = 1 To 9
               If x <= y Then
                   Console.Write("{0}*{1}={2}{3}", x, y, x * y, vbTab)
               Else
                   For v = 0 To 7
                       Console.Write(Chr(32))
                   Next
               End If
           Next
    Next
End Sub
5.三角形输出 IV
Sub main()
Dim i As Integer, j As Integer
       For i = 1 To 9
           For j = i To 9
               RichTextBox1.Text = RichTextBox1.Text & i & "*" & j & "=" & i * j & vbTab
           Next
           RichTextBox1.Text = RichTextBox1.Text & Chr(13)
       Next
End Sub
6.三角形输出 V
Sub main()
       For i = 1 To 9
           For j = 1 To i
           Next
       Next
End sub
7.三角形输出 VI
Sub main()
For i = 9 To 1 Step -1
           For p = 1 To i
               For x = 0 To 7
                   RichTextBox1.Text = RichTextBox1.Text & Chr(32)
               Next
           Next
           For j = i To 9
           Next
       Next
End sub
8.三角形输出 VII
Sub main()
For i = 1 To 9
           For p = i To 9
               For x = 0 To 7
               Next
           Next
           For j = 1 To i
           Next
       Next
End Sub
9.矩形分段输出 VIII
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
       Dim i As Integer, j As Integer, m As Integer, n As Integer, p As Integer, q As Integer
       For j = 1 To 9
           For i = 1 To 3
           Next
       Next
       For n = 1 To 9
           For m = 4 To 6
               RichTextBox1.Text = RichTextBox1.Text & m & "*" & n & "=" & m * n & vbTab
           Next
       Next
       For q = 1 To 9
           For p = 7 To 9
               RichTextBox1.Text = RichTextBox1.Text & p & "*" & q & "=" & p * q & vbTab
           Next
       Next
   End Sub
最后修改:2013/4/6 18:20:54
13-04-04 15:53
贴了那么多,老鸟不屑看么,菜鸟看不懂,还不如贴个流程图出来。
Good Luck~
13-04-04 17:45
不错,以前也学过一些。
13-04-05 10:35
