首页 PLC论坛 PLC论坛
主题:s7-300程序
点击:518 回复:3
OPN   DB    19
     L     P#0.0
     LAR1
     L     #Num
     T     #num1
_001: NOP   0
     L     #num1
     L     1
     >=I
     JNB   _002
     A     DBX [AR1,P#0.0]
     =     DBX [AR1,P#20.0]
     +AR1
     L     #num1
     L     1
     -I
     T     #num1
     JU    _001
_002: NOP   0
OPN   DB    19
     L     P#0.0
     LAR1
     L     #Num
     T     #num1
_011: NOP   0
     L     #num1
     L     1
     >=I
     JNB   _015
     A     #bQj
     JNB   _013
     A     DBX [AR1,P#20.0]
     =     DBX [AR1,P#0.1]
     JU    _014
_013: NOP   0
     A     #bHt
     JNB   _014
     A     DBX [AR1,P#20.1]
     =     DBX [AR1,P#0.0]
_014: NOP   0
     +AR1
     L     #num1
     L     1
     -I
     T     #num1
     JU    _011
_015: NOP   0
 OPN   DB    19
     A     #bHt
     JNB   _065
     L     P#0.0
     LAR1
     L     #Num
     L     1
     -I
     T     #num1
_061: NOP   0
     L     #num1
     L     1
     >=I
     JNB   _062
     +AR1
     L     #num1
     L     1
     -I
     T     #num1
     JU    _061
_062: NOP   0
     A     DB19.DBX   18.7
     =     DBX [AR1,P#0.0]
_065: NOP   0
 A     #bQj
     JNB   _031
     A     #bHead
     =     DB19.DBX    0.0
_031: NOP   0
OPN   DB    19
     A     #bQj
     JNB   _045
     L     P#0.0
     LAR1
     L     #Num
     T     #num1
_041: NOP   0
     L     #num1
     L     1
     >=I
     JNB   _045
     +AR1
     L     #num1
     L     1
     -I
     T     #num1
     JU    _041
_045: NOP   0
     A     DBX [AR1,P#0.0]
     =     DB19.DBX   18.7
能不能帮我理解一下这段程序。小弟在这里感激不尽。
13-02-19 08:34
这么长的程序也没有啥的,间接寻址去理解清楚便可,熟悉我的人都知道,我不会对从PLC上载的无符号表的程序做过多解释。
Good Luck~
13-02-19 08:38
做梯形图是否会更直观点啊?
13-02-19 10:07
引用 kailuoyu 在 2013/2/19 10:07:06 发言【内容省略】
梯形图不支持间接寻址。
Good Luck~
13-02-19 10:31
