程序段1:
L #Fault_In //************************************************
L 0 // 说的意思是:拿#Fault_In 与0比较,如果#Fault_In
<>I // 不等于0则跳转到L1去,否则程序继续向下执行;
JC L1 //************************************************
程序段2:
JU L2 //********无条件跳转到L2**************************
程序段3:
L1:SET //*******逻辑结果之1 *****************************
= #Fault_Alarm //*******故障报警输出*****************************
JU L3 //*******无条件跳转到L3***************************
程序段4:
L2:CLR
= #Fault_Alarm //*******故障报警清楚或无报警***********************
程序段5:
L3: L #Fault_Temp // **************************************************
INVI //对#Fault_Temp 求反码后,再传送到#Fault_Temp 里去
T #Fault_Temp //***************************************************
L #Fault_In //***************************************************
L #Fault_Temp //#Fault_In 和#Fault_Temp 与运算后,再传送到
AW // #Fault_Temp里去
L #Fault_Temp //***************************************************
L 0 //#Fault_Temp和0比较,如果#Fault_Temp不等于0结果为真,
<>I //则就把#Fault_Horn置为
S #Fault_Horn //***************************************************
T #Fault_Temp //把 #Fault_In值给 #Fault_Temp
最后修改:2012/12/25 14:17:09
