首页 单片机论坛
主题:5V逻辑
点击:484 回复:1
[URL=http://www.bdtic.com/ST/Analog-Mixed/index.html][/URL]
5V逻辑[/URL]5V逻辑
型号
概述
74VHC00
Quad 2 Input NAND Gate
74VHC02
Quad 2 Input NOR Gate
74VHC04
Hex Inverter
74VHC05
HEX Inverter (Open Drain)
74VHC08
Quad 2 Input AND Gate
74VHC125
Quad Bus Buffer (3-State)
74VHC132
Quad 2 input Schmitt NAND Gate
74VHC138
3 to 8 Line Decoder (Inverting)
74VHC14
Hex Schmitt Inverter
74VHC157
Quad 2 Channel multiplexer
74VHC174
Hex D Type Flip Flop with Clear
74VHC238
3 to 8 Line Decoder
74VHC244
Octal Bus Buffer with 3-state Outputs (Not inverted)
74VHC245
Octal Bus Transceiver (3-state)
74VHC27
Triple 3 Input NOR Gate
74VHC273
Octal D Type Flip Flop with Clear
74VHC32
Quad 2 Input OR Gate
74VHC373
Octal D Type Latch with 3-state Outputs Non Inverting
74VHC374
Octal D Type Flip Flop with 3-state Outputs Non Inverting
74VHC541
74VHC573
74VHC574
74VHC594
8 Bit Shift Register with Output Register
74VHC74
Dual D Type Flip-Flop With preset & Clear
74VHC86
Quad Exclusive OR Gate
74VHCT00A
74VHCT04A
Hex Inverter
74VHCT08A
74VHCT125A
74VHCT138A
74VHCT238A
3 to 8 Line Decoder
74VHCT244A
74VHCT245A
74VHCT273A
74VHCT32A
74VHCT541A
74VHCT574A
74VHCU04
Hex Inverter (Single Stage)
HCF4001
Quad 2-Input NOR Gate
HCF4007U
Dual Complementary Pair Plus Inverter
HCF4010
Hex Buffer/Converters non Inverting
HCF40103
Presettable 8-Bit Binary Down Counter
HCF40106
Hex Schmitt Trigger
HCF4011
Quad 2-Input NAND Gate
HCF4013
Dual D Flip-Flop
HCF4014
8-Stage Static Syncr. Shift Register
HCF4016
Quad Bilateral Switch
HCF4017
Decade Counter/Divider
HCF4019
Quad AND/OR Select Gate
HCF4020
14-Stage Binary/Ripple Counter
HCF4021
8-Stage Static Shift Register
HCF4024
7-Stage Binary/Ripple Counter
HCF4025
Triple 3-Input NOR Gate
HCF4030
HCF4040
12-Stage Binary/Ripple Counter
HCF4042
Quad Clocked D Latch
HCF4047
Monostable/Astable Multivibrator
HCF4049U
Hex Inverting Buffer/Converter
HCF4050
Hex Non Inverting Buffer/Converter
HCF4051
Single 8-Channel Analog Multiplexer/Demultiplexer
HCF4052
Different 4 Channel Analog Multiplexer/Demultiplexer
HCF4053
Triple 2-Channel Analog Multiplexer/Demultiplexer
HCF4056
BCD to 7-Segment Decoder/Driver
HCF4060
14-Stage Counter/Driver AND Oscillator
HCF4066
HCF4067
Single 16-Channel Analog Multiplexer/Demultiplexer
HCF4069U
Hex Inverter
HCF4070
Quad Ex-OR Gate
HCF4077
Quad ex-NOR Gate
HCF4081
Quad 2-Input AND Gate
HCF4093
Quad 2-Input NAND Schmitt Trigger
HCF4094
8-Stage Shift-AND-Store Bus Register
HCF4097
Different. 8-Channel Analog Multiplexer/Demultiplexer
HCF4098
Dual Monostable Multivibrator
HCF4099
8-Bit Addressable Latch
HCF4538
Dual Precision Monostable Multivibrator
HCF4541
Programmable Timer
HCF4555
Dual 1-Of-4 Decoder/Demultiplexer (Out. High)
HCF4556
Dual 1-of-4 Decoder/Demultiplexer (Out. Low)
M22100
4x4 Crosspoint Switch With Control Memory
M74HC00
M74HC02
M74HC03
Quad 2-Input NAND (Open Drain)
M74HC04
Hex Inverter
M74HC08
M74HC10
Triple 3-Input NAND Gate
M74HC107
Dual J-K Flip-Flop With Clear
M74HC109
Dual J-K Flip-Flop With Preset & Clear
M74HC123
Dual Retrigg. Monostable Multivibrator with Clear
M74HC125
M74HC126
M74HC132
Quad 2-Input Schmitt NAND Gate
M74HC133
13-Input NAND Gate
M74HC138
3 to 8 Line Decoder (Inv.)
M74HC139
Dual 2 to 4 Line Decoder/Demultiplexer
M74HC14
M74HC148
8 to 3 Line Priority Encoder
M74HC151
8-Channel Multiplexer
M74HC153
Dual 4-Channel Multiplexer
M74HC157
Quad 2-Channel Multiplexer
M74HC160
Synchronous Decade Counter With Async. Clear
M74HC161
Synchronous Binary Counter With Async. Clear
M74HC163
Synchronous Binary Counter With Sync. Clear
M74HC164
8-Bit SIPO shift register
M74HC165
8 Bit PISO Shift Register
M74HC174
Hex D-Type Flip-Flop With Clear
M74HC175
Quad D-Type Flip-Flop With Clear
M74HC191
4 Bit Synchronous Binary Up/Down Counter
M74HC20
Dual 4-Input NAND Gate
M74HC221
M74HC238
3 to 8 Line Decoder
M74HC240
Octal Bus Buffer (3-State/Inv.)
M74HC241
Octal Bus Buffer (3-State)
M74HC244
M74HC245
M74HC251
8-Channel Multiplexer (3-State)
M74HC253
Dual 4-Channel Multiplexer (3-State)
M74HC257
Quad 2-Channel Multiplexer (3-State)
M74HC259
8 Bit Addressable Latch
M74HC266
Quad Exclusive Nor Gate With Open Drain
M74HC27
M74HC273
Octal D-Type Flip-Flop with Clear
M74HC280
9 Bit Parity Generator
M74HC283
4 Bit Binary Full Adder
M74HC299
8 Bit PIPO Shift Register (3-State)
M74HC32
Quad 2-Input OR Gate
M74HC365
Hex Bus Buffer (3-State)
M74HC367
M74HC368
Hex Bus Buffer (3-State/Inv.)
M74HC373
Octal D-Type Latch (3-State)
M74HC374
Octal D-Type Flip-Flop (3-State)
M74HC377
M74HC390
Dual Decade Counter
M74HC393
Dual Binary Counter
M74HC4016
M74HC4017
M74HC4020
14-Stage Binary Counter
M74HC4024
7-Stage Binary Counter
M74HC4040
12-Stage Binary Counter
M74HC4049
Hex Buffer/Converter (Inv.)
M74HC4050
M74HC4051
M74HC4052
Dual 4-Channel Analog Multiplexer/Demultiplexer
M74HC4053
M74HC4060
14-Stage Binary Counter/Oscillator
M74HC4066
M74HC4075
Triple 3-Input OR Gate
M74HC4078
8-Input NOR/OR Gate
M74HC4094
8 Bit SIPO Shift Register Latch (3-State)
M74HC4316
M74HC4518
Dual Decade Counter
M74HC4520
Dual 4 Bit Binary Counter
M74HC4538
M74HC4543
BCD to 7-Segment L/D/D (LCD)
M74HC4851
Single 8 Channel Analog Mux/Demux With Injection Current Protection
M74HC4852
DUAL 4 Channel Analog Mux/Demux With Injection Current Protection
M74HC51
Dual 2-Wide 2-Input AND-OR Inv. Gate
M74HC533
Octal D-Type Latch (3-State/Inv.)
M74HC534
Octal D-Type Flip-Flop (3-State/Inv.)
M74HC540
M74HC541
M74HC563
M74HC564
M74HC573
M74HC574
M74HC590
8 Bit Binary Counter Register (3-State)
M74HC592
M74HC595
8 Bit Shift Register Output Latch (3-State)
M74HC597
8 Bit Latch Shift Register
M74HC688
8 Bit Equality Comparator
M74HC7266
Quad Exclusive NOR Gate
M74HC73
M74HC74
Dual D-Type Flip-Flop With Preset & Clear
M74HC86
M74HCT00
M74HCT04
Hex Inverter
M74HCT08
M74HCT132
M74HCT138
M74HCT14
M74HCT157
M74HCT244
M74HCT245
M74HCT273
M74HCT32
M74HCT367
M74HCT373
M74HCT374
M74HCT4051
SINGLE 8 CHANNEL ANALOG MULTIPLEXER/DEMULTIPLEXER
M74HCT4053
M74HCT540
M74HCT541
M74HCT573
M74HCT574
M74HCT640
Octal Bus Transceiver (3-State/Inv.)
M74HCT652
Octal Bus Transceiver Register (3-State)
M74HCT7007
Hex Buffer
M74HCT74
M74HCU04
[/URL]
12-08-08 14:54
该帖内容不符合相关规定!
23-04-05 15:08
