How to connect FIX software with GENIUS BUS(plc70-90)
> I'am a engineer of CHINA COAL.I take charge for programe control in COAL PREPARETION PLANT .Our PC which had configure software had a malfunction three days ago,We have no way but to reinstall FIX32 software.It had a problem
> to communicate PC Interface Module(pcim) with GENIUS BUS (plc70-90).The faceplate' OK LED are all off,No matter how we reset DIP switch and configure parameter(IO address,Memory address etc) ,we cann't successfully finish the FIX32 normal communication.
> Waiting for your help,Give my best wishes.
yanjun041@sohu.com
