void Filt(char code[],char c)
if(c=='F')
if(code[0]>=0X7E)
code[1]=code[0]-0X7E;
code[0]=0X7E;
else
code[1]=0XFF; /*0XFF作为标记code[1]不可能产生0XFF*/
else if(c=='H')
if(code[0]!=0X7E)
code[1]=0xFE; /*转换完成标记*/
else
if(code[1]==0XFE)
code[1]=0XFF; /*接收下一个码的标记*/
else
code[0]=code[0]+code[1];
code[1]=0XFE;
发送时:
char SendChar[2]; /*存储发送的值*/
SendChar[0]=c; /*c为待发ASCII码*/
Filt(SendChar,'F');
if(SendChar(1)==0XFF)
..... /*发送SendChar[0]*/
else
...... /*发送SendChar[0],SendChar[1]*/
接收时:
char ReceiveChar[2]; /*存储接收的值*/
ReceiveChar[0]=c0; /*c0接收的ASCII码*/
Filt(ReceiveChar,'H');
if(ReceiveChar[1]==0xFF)
ReceiveChar[1]=c1; /*c1为下一个*/
Filt(ReceiveChar,'H);
else if(ReceiveChar[1]==0xFE)
...... /*存储转换后的ReceiveChar[0]*/
