首页 电脑编程
主题:求教VB上使用MODBUSRTU方式带CRC校验时发送大于127的数据的方法
点击:3427 回复:5
本人使用VB编写了一个上位机于单片机的通讯程序,使用的是MODBUSRTU方式,带CRC校验的,发出去的数据单片机能收到,并且有回答,但是遇到asc码>127时显示的是3F(溢出),不知道该如何修改,这方面没学好-_-!!
部分代码如下:
Option Explicit
Dim sendlen, reclen
Private RTUCRC As String
Dim outbyte() As Byte
Dim hexchrgroup() As Byte
Dim n As Integer
Private Sub cboHexAscii_Click()   '选择发送方式
   If cboHexAscii.Text = "按ASCII码" Then
       intOutMode = 0
   Else
       intOutMode = 1
   End If
End Sub
Private Sub chkAscii_Click()
If chkAscii.Value = 1 Then
       intAsciiChk = 1
   Else
       intAsciiChk = 0
   End If
End Sub
Private Sub chkHex_Click()
If chkHex.Value = 0 Then
       intHexChk = 0
   Else
       intHexChk = 1
   End If
End Sub
Private Sub Manual_Click()    '手动发送选择
        If auto.Value = True Then
             ctrTimer.Enabled = False
             cmdPortOpen.Enabled = False
       Else
             ctrTimer.Enabled = True
             cmdPortOpen.Enabled = True
       End If
End Sub
Private Sub auto_Click()                 '自动发送选择
        If ctrMSComm.PortOpen = False Then
          MsgBox "串口未打开", , "错误信息"
        End If
        If ctrMSComm.PortOpen = True Then
             cmdManualSend.Enabled = False
        Else
             cmdManualSend.Enabled = True
        End If
        End If
        Call RTUcheck
        Call Hexsent
End Sub
Private Sub cmdExit_Click()   '退出
       Unload Me
End Sub
Private Sub cmdPortOpen_Click()              '串口打开
        On Error Resume Next
       Else
       End If
       If ctrMSComm.PortOpen Then                             '打开关闭按钮显示文字及combo1使能
            cmdPortOpen.Caption = "关闭串口"
            Combo1.Enabled = False
       Else
             cmdPortOpen.Caption = "打开串口"
             Combo1.Enabled = True
       End If
       If Err Then                                         '打开串口失败,则显示出错信息
        MsgBox Error$, 48, "错误信息"
        Exit Sub
      End If
End Sub
Private Sub cmdStop_Click()              '停止
   Else
   End If
End Sub
'串口选择
Private Sub Combo1_Click()
             ctrMSComm.CommPort = Combo1.ListIndex + 1
End Sub
'数据位改变
Private Sub Combo2_Click()
       Call setting
End Sub
'波特率改变
Private Sub Combo3_Click()
       Call setting
End Sub
'奇偶校验改变
Private Sub Combo4_Click()
       Call setting
End Sub
'停止位改变
Private Sub Combo5_Click()
       Call setting
End Sub
Private Sub setting()        '通讯参数设置
ctrMSComm.Settings = CStr(Combo3.Text) & "," & CStr(Combo4.Text) & "," & CStr(Combo2.Text) & "," & CStr(Combo5.Text)
End Sub
Private Sub cmdClear_Click()   '清除
   txtReceive.Text = ""
   Stxt.Text = ""
   Dim bytTemp(0) As Byte
   ReDim bytReceiveByte(0)
   intReceiveLen = 0
   Call InputManage(bytTemp, 0)
   Call GetDisplayText
End Sub
Private Sub cmdManualSend_Click()    '手动发送
       Call ctrTimer_Timer
       Call RTUcheck
       Call Hexsent
End Sub
Private Sub cmdReceive_Click()      '接收
   If blnReceiveFlag Then
       If Not blnAutoSendFlag And Not blnReceiveFlag Then
       End If
       cmdReceive.Caption = "开始接收"
   Else
       ctrMSComm.InputLen = 0
       ctrMSComm.InputMode = 0
       ctrMSComm.InBufferCount = 0
       ctrMSComm.RThreshold = 1
       cmdReceive.Caption = "停止接收"
   End If
   blnReceiveFlag = Not blnReceiveFlag
End Sub
Private Sub ctrMSComm_OnComm()   '通讯
   Dim bytInput() As Byte
   Dim intInputLen As Integer
   Dim hexchr As String, i As Integer, hexstring As String, j As Integer, answerVAL As String
               '此处添加处理接收的代码
               'ctrMSComm.InputMode = comInputModeBinary
               hexstring = ctrMSComm.Input
               i = Len(hexstring)
               For j = 1 To i
               hexchr = Mid(hexstring, j, 1)
              If Hex(Asc(hexchr)) < 16 Then               '如果hexchr(asc(chr)>128  溢出 为3F
               txtReceive.Text = txtReceive.Text & "0" & Hex(Asc(hexchr)) & " "
               Else
               txtReceive.Text = txtReceive.Text & Hex(Asc(hexchr)) & " "
               End If
               'txtReceive.Text = txtReceive.Text & ctrMSComm.Input & CStr(Chr(13)) & CStr(Chr(10))
               Next j
               Call InputManage(bytInput, intInputLen)
               Call GetDisplayText
              txtReceive.Text = txtReceive.Text & CStr(Chr(13)) & CStr(Chr(10))
               End If
End Sub
Private Sub time_Change()             '发送时间间隔调整输入
       Dim number As String
       Dim num As Integer
       Dim numcyc As Integer
       num = Len(time.Text)
       For numcyc = 1 To num
           number = Mid(time.Text, numcyc, 1)
           Select Case InStr("0123456789", number)
           Case 0
              MsgBox "输入时间间隔错误,请重新输入", , "错误信息"
              Exit Sub
           End Select
       Next
        ctrTimer.Interval = time.Text
End Sub
Private Sub ctrTimer_Timer()    '自动发送定时
     Dim longth As Integer
      strSendText = txtSend.Text
     If intOutMode = 0 Then
       ctrMSComm.Output = txtSend.Text
       Else
       longth = strHexToByteArray(strSendText, bytSendByte())
       If longth > 0 Then
           ctrMSComm.Output = bytSendByte
       End If
       End If
       Call Hexsent
       Call RTUcheck
  End If
End Sub
Private Sub ctrTimer2_Timer()    '状态刷新定时器
        StatusBar.Panels(1).Text = "串口选择:" & CStr(Combo1.Text)
        StatusBar.Panels(2).Text = "串口设置:" & CStr(ctrMSComm.Settings)
        StatusBar.Panels(3).Text = "时间间隔:" & CStr(time.Text)
End Sub
'初始化
Private Sub Form_Load()
   '设置默认发送接收关闭状态
   blnAutoSendFlag = False
   blnReceiveFlag = False
   ctrMSComm.OutBufferCount = 0
   '接收初始化
   intReceiveLen = 0
   '默认发送方式为ASCII
   intOutMode = 1
   intHexChk = 1
   chkAscii.Value = intAsciiChk
   chkHex.Value = intHexChk
   '显示初始化
   Call cmdClear_Click
    '初始化串行口
   Dim d%
           For d = 1 To 6
                  Combo1.AddItem ("COM" & CStr(d))
           Next
                  Combo1.ListIndex = 1
           Combo2.AddItem "6"
           Combo2.AddItem "7"
           Combo2.AddItem "8"
           Combo2.ListIndex = 2
           Combo3.AddItem "1200"
           Combo3.AddItem "2400"
           Combo3.AddItem "4800"
           Combo3.AddItem "9600"
           Combo3.AddItem "19200"
           Combo3.AddItem "38400"
           Combo3.AddItem "57600"
           Combo3.AddItem "115200"
           Combo3.ListIndex = 6
           Combo4.AddItem "n"
           Combo4.AddItem "o"
           Combo4.AddItem "e"
           Combo4.AddItem "m"
           Combo4.AddItem "s"
           Combo4.ListIndex = 0
           Combo5.AddItem "1"
           Combo5.AddItem "2"
           Combo5.ListIndex = 0
        txtSend.Text = "030300000000"
        time.Text = 1000
        Manual.Value = True
        Else
        End If
End Sub
Private Sub RTUcheck()                             'RTU校验
 Dim a As Integer
       Dim CRC() As Byte
       Dim d() As Byte
       Dim RECstring As String
       Dim b As Integer, chrlength As Integer, temp As String
       RECstring = txtSend.Text
       chrlength = Len(RECstring)
       a = chrlength / 2 - 1
       ReDim d(a) As Byte
       For b = 0 To chrlength / 2 - 1
                 temp = Mid(RECstring, b * 2 + 1, 2)
                 d(b) = Val("&H" & temp)
       Next
       RTUCRC = CRC16(d)                   '调用CRC16计算函数, CRC(0)为高位,  CRC(1)为低位
       Stxt.Text = txtSend + RTUCRC
End Sub
Private Sub Hexsent()                           '发送子程序
       Dim hexchrlen%, hexchr As String, hexcyc%, hexmid As String
       Dim i, j As Integer
              hexchrlen = Len(Stxt)
              For hexcyc = 1 To hexchrlen          'hexcyc=1to16     检查发送的数值是否合适
              hexchr = Mid(Stxt, hexcyc, 1)
              If InStr("0123456789ABCDEFabcdef", hexchr) = 0 Then
                    MsgBox "无效的数值,请重新输入", , "错误信息"
                    Exit Sub
               End If
              Next
              ReDim outbyte(1 To hexchrlen / 2) As Byte
              For i = 1 To hexchrlen / 2
                    hexcyc = 2 * i - 1
                    hexchr = Mid(Stxt, hexcyc, 2)
                    hexmid = CStr(hexchr)
                    outbyte(i) = Val("&H" + hexmid)
                Next i
             ctrMSComm.Output = outbyte()
   End Sub
Private Function DecToHex(nNum As Integer) As String
Dim str1, str2 As String
Dim num1, num2 As Integer
   num1 = nNum \ 16 '除数
   If num1 >= 10 Then
       str1 = Chr(65 + num1 - 10) '显示A TO F
   Else
       str1 = str(num1)
   End If
   num2 = nNum Mod 16 '余数
   If num2 >= 10 Then
       str2 = Chr(65 + num2 - 10) '显示A TO F
   Else
       str2 = str(num2)
   End If
   DecToHex = "0x" & Right(str1, 1) & Right(str2, 1)
End Function
Private Function CRC16(data() As Byte) As String              'CRC校验程序
     Dim CRC16Lo As Byte, CRC16Hi As Byte       'CRC寄存器
     Dim CL As Byte, CH As Byte                 '多项式码&HA001
     Dim CRCLo As String, CRCHi As String
     Dim SaveHi As Byte, SaveLo As Byte
     Dim i As Integer
     Dim Flag As Integer
     CRC16Lo = &HFF
     CRC16Hi = &HFF
     CL = &H1
     CH = &HA0
     For i = 0 To UBound(data)
       CRC16Lo = CRC16Lo Xor data(i)            '每一个数据与CRC寄存器进行异或
       For Flag = 0 To 7
         SaveHi = CRC16Hi
         SaveLo = CRC16Lo
         CRC16Hi = CRC16Hi \ 2                  '高位右移一位
         CRC16Lo = CRC16Lo \ 2                  '低位右移一位
         If ((SaveHi And &H1) = &H1) Then       '如果高位字节最后一位为1
           CRC16Lo = CRC16Lo Or &H80            '则低位字节右移后前面补1
         End If                                 '否则自动补0
         If ((SaveLo And &H1) = &H1) Then       '如果LSB为1,则与多项式码进行异或
           CRC16Hi = CRC16Hi Xor CH
           CRC16Lo = CRC16Lo Xor CL
         End If
       Next Flag
     Next i
     If Len(Hex(CRC16Hi)) = 1 Then
        CRCHi = "0" + Hex(CRC16Hi)
     Else
        CRCHi = Hex(CRC16Hi)
     End If
     If Len(Hex(CRC16Lo)) = 1 Then
        CRCLo = "0" + Hex(CRC16Lo)
     Else
        CRCLo = Hex(CRC16Lo)
     End If
        CRC16 = CRCLo + CRCHi
 End Function
'字符表示的十六进制数转化为相应的整数      (16进制数--->10进制)
'错误则返回  -1
Function ConvertHexChr(str As String) As Integer
   Dim test As Integer
   test = Asc(str)
   If test >= Asc("0") And test <= Asc("9") Then
       test = test - Asc("0")
   ElseIf test >= Asc("a") And test <= Asc("f") Then
       test = test - Asc("a") + 10
   ElseIf test >= Asc("A") And test <= Asc("F") Then
       test = test - Asc("A") + 10
   Else
       test = -1                                       '出错信息
   End If
   ConvertHexChr = test
End Function
'字符串表示的十六进制数据转化为相应的字节串     (16进制--->文本模式)
'返回转化后的字节数
Function strHexToByteArray(strText As String, bytByte() As Byte) As Integer
   Dim HexData As Integer          '十六进制(二进制)数据字节对应值
   Dim hstr As String * 1          '高位字符
   Dim lstr As String * 1          '低位字符
   Dim HighHexData As Integer      '高位数值
   Dim LowHexData As Integer       '低位数值
   Dim HexDataLen As Integer       '字节数
   Dim StringLen As Integer        '字符串长度
   Dim Account As Integer          '计数
   strText = ""                    '设初值
   HexDataLen = 0
   strHexToByteArray = 0
   StringLen = Len(strText)
   Account = StringLen \ 2
   ReDim bytByte(Account)
   For n = 1 To StringLen
       Do                                              '清除空格(高位)
           hstr = Mid(strText, n, 1)
           n = n + 1
           If (n - 1) > StringLen Then
               HexDataLen = HexDataLen - 1
               Exit For
           End If
       Loop While hstr = " "
       Do
           lstr = Mid(strText, n, 1)                   '(低位)
           n = n + 1
               Exit For
           End If
       Loop While lstr = " "
       n = n - 1
       If n > StringLen Then
           Exit For
       End If
       HighHexData = ConvertHexChr(hstr)
       LowHexData = ConvertHexChr(lstr)
       If HighHexData = -1 Or LowHexData = -1 Then     '遇到非法字符中断转化
           Exit For
       Else
           HexData = HighHexData * 16 + LowHexData
           bytByte(HexDataLen) = HexData
           HexDataLen = HexDataLen + 1
       End If
   Next n
   If HexDataLen > 0 Then                              '修正最后一次循环改变的数值
       ReDim Preserve bytByte(HexDataLen)
   Else
       ReDim Preserve bytByte(0)
   End If
   If StringLen = 0 Then                               '如果是空串,则不会进入循环体
   Else
       strHexToByteArray = HexDataLen + 1
   End If
End Function
05-02-02 10:05
模块:
'接收模块
Public bytReceiveByte() As Byte     '接收到的字节
Public intReceiveLen As Integer     '接收到的字节数
'显示模块
Public strAddress As String     '地址信息
Public strHex As String         '十六进制编码
Public strAscii As String        'ASCII码
'输入处理
'处理接收到的字节流,并保存在全局变量
'bytReceiveRyte()
Public Sub InputManage(bytInput() As Byte, intInputLenth As Integer)
   Dim n As Integer                                '定义变量及初始化
   ReDim Preserve bytReceiveByte(intReceiveLen + intInputLenth)
   For n = 1 To intInputLenth Step 1
       bytReceiveByte(intReceiveLen + n - 1) = bytInput(n - 1)
   Next n
   intReceiveLen = intReceiveLen + intInputLenth
End Sub
'为输出准备文本
'保存在全局变量
'strText
'strHex
'strAddress
'总行数保存在
'intLine
Public Sub GetDisplayText()
   Dim n As Integer
   Dim intValue As Integer
   Dim intHighHex As Integer
   Dim intLowHex As Integer
   Dim strSingleChr As String * 1
   Dim intAddress As Integer
   Dim intAddressArray(8) As Integer
   Dim intHighAddress As Integer
   strAscii = ""            '设置初值
   strHex = ""
   strAddress = ""
   '获得16进制码和ASCII码的字符串
   For n = 1 To intReceiveLen
       intValue = bytReceiveByte(n - 1)
       If intValue < 32 Or intValue > 128 Then         '处理非法字符
           strSingleChr = Chr(46)                      '对于不能显示的ASCII码,
       Else                                            '用"."表示
           strSingleChr = Chr(intValue)
       End If
       strAscii = strAscii + strSingleChr
       intHighHex = intValue \ 16
       intLowHex = intValue - intHighHex * 16
       If intHighHex < 10 Then
           intHighHex = intHighHex + 48
       Else
           intHighHex = intHighHex + 55
       End If
       If intLowHex < 10 Then
           intLowHex = intLowHex + 48
       Else
           intLowHex = intLowHex + 55
       End If
       strHex = strHex + " " + Chr$(intHighHex) + Chr$(intLowHex) + " "
      ' If (n Mod intHexWidth) = 0 Then                 '设置换行
      '     strAscii = strAscii + Chr$(13) + Chr$(10)
      '     strHex = strHex + Chr$(13) + Chr$(10)
      ' Else
      ' End If
   Next n
End Sub
05-02-02 10:05
请教知道的人。。。email:summer_sunjie@sina.com
05-02-02 10:06
应该有办法﹐不过好象以前有见到的﹐
05-03-06 13:11
因为ASC
05-04-27 22:59
up
05-06-02 14:37
