首页 运动控制 运动控制
主题:Flying Saw Pipe Length computer pneumatic control devices
点击:310 回复:0
Flying Saw  http://www.chinasrt.com
The invention relates to a fixed-length welded steel production cut-controlled flying saws computer cut to length steel pneumatic control device, characterized by: saw the car in the optical encoder device set to measure the speed and length of the pipe; settings are controllable pan The clamping device for the second error correction residual Length; in electrical circuits using computer control box, the utility model has the advantage of high accuracy, low price, easy installation, low failure rate, easy maintenance, suitable for the existing pneumatic flying fixed-length steel cutting saw improvements, get a higher economic efficiency.
11-11-28 13:59
