http://blog.gkong.com/uploadfile4/20111017151156235.jpg[/URL]
The highest quality and reasonable priceof Multimedia pc share ,Support full-screen movies
Today’s PCs are Like Supercomputers
Qotom virtual PC solutions are based on a simple fact: today’s PCs are so powerful that the vast majority of people use only a small fraction of their available Qotom capacity. The Qotom-M03 taps this unused capacity so that up to seven users can simultaneously share a single PC. Each user gets their own personal Qotom environment (applications, settings, files and preferences), but at a fraction of what it would cost to deploy individual computers. So even though seven people share a single system, they each get their own rich PC experience.
Easy to Install
Each Qotom-M03 kit contains a PCI card, virtualization software, and three access devices. Setup is easy. Just install the PCI card and virtualization software on the shared PC. Then connect the access devices to the PCI card with the supplied cables. Finally, connect each user’s monitor, keyboard, and mouse to their access device. Now, four users can enjoy their own independent virtual desktops (one on the shared PC and three on virtual PCs). Add a second Qotom-M03 kit and seven users can simultaneously share a single PC.
Powerful and Flexible
The access devices themselves are small, silent, and have no moving parts. Yet they deliver a rich Windows or Linux PC experience. Users can enjoy multimedia with sound and full-motion video at screen resolutions of 800x600 and 1024x768. Software applications run simultaneously and independently on each virtual desktop so that users don’t even know they are sharing a PC. Best of all, most software applications run right out of the box, so your staff and users won’t need any special training.
Cost-Effective and Efficient
With the Qotom-M03, you can easily lower your Qotom acquisition and support costs by up to 70%. You will also save money on electricity–the highly efficient Qotom-M03 uses about 1 watt of electricity per added user (compared to 115 watts for a typical PC). With a longer useful life and far fewer parts, the Qotom solution also helps reduce e-waste, a growing problem around the world.
Liberate the power of your PCs
Why select the Qotom-M03?
Cut Qotom costs by 70%
Easy to set up, maintain and support Rich PC environment runs Windows and Linux Eco-friendly running at 1 watt per added user
The Qotom-M03 is ideal for:
Classrooms and libraries
Small business
Internet and email
Public access
Key Features & Benefits
Share one PC with up to seven users
Slash Qotom acquisition and support costs
Easy to set up, maintain, and secure
Compact, reliable, and energy-efficient (no fans or disks)
Includes powerful virtualization (terminal services)
Software for Windows/Linux
Supports standard applications, including multimedia
Connect users directly to the shared PC via standard
Cables up to 10 m (33 ft.) long
Qotom-M03 Multi-user Kit Datasheet
Hardware
Size
Access Device: 110*65 *28 mm
PCI Card: Low profile PCI plug-in card (includes standard and low profile PCI bracket) Shipping Size: 138*138*98mm
Weight
Qotom-M03 Access Terminal: 70g*3+80g*1
Shipping Weight (includes power adapter, packaging, documentation, etc. ): 460g
Power Supply
No external power adapters are required
Power to the access devices is provided by the PCI card through the cable
LED Indicator
Power/Connection: Green LED located on front of access device
Peripheral Connections
01 – Speaker Output
02 – Keyboard Port
03 – Mouse Port
04 – Video port
05 – ETHERNET
Connection to Host PC
Standard Category 5 or 5e UTP cable: up to 5 meters (16 feet)
Standard Category 6 STP cable: up to 7 meters (23 feet)
Video Resolution
800x600 and 1024x768, 16-bit color maximum, 60 Hz refresh rate.
Audio
Stereo output via speaker port
Data Security
No USB ports on access device ensure absolute data security
USB ports on host PC can be assigned to different users
Note: Local user access to USB ports requires separate USB extension cables -- not included
Reliability (MTBF)
>100,000 hours (calculated using Bell core Issue 6 TR-332, Case 2, Part I at 40°C)
TERMINAL SERVICES SOFTWARE
Max # Users
Per PC
Each Qotom-M03 kit adds 3 users to a host PC. A maximum of two kits can be used with one PC to get a total of 7 users (3 for each kit plus 1 on the host)
User Software
Qotom terminal services software
Supported Operating
Systems
l Microsoft Windows and Linux
SYSTEM REQUIREMENTS AND OPTIONS
Kit Contents
One Qotom-M03 Kit includes three (3) access devices, one PCI card, Terminal services software installation CD, and Quick Installation Guide.
l The number of users on individual host will depend upon the host system capabilities as well as the applications used and performance expectations for those applications. It is recommended that new customers test their application(s) before adding additional users.
l Does not support 3D games.
l Application software and OS licenses for the host PC may be required by the respective software vendor and must be purchased separately.
var imgs = get("richTextDescription").getElementsByTagName("img");
for(var i=0;i586 || this.height>586){
if(this.width>this.height){
setImgSizeWH("",this,586,586*this.height/this.width);
}else{
setImgSizeWH("",this,586*this.width/this.height,586);
