首页 DCS论坛 DCS论坛
主题:谁有SQL Server 2000 SP3 For Wincc分享一个啊?
点击:2702 回复:2
[size=4]谁有SQL Server 2000 SP3 For Wincc分享一个啊?
装PCS7 V6.1时老是出现
The installation requirements have not been met for the following products:
WinCC  V6.0 incl. SP3 ASIA
The WinCC instance of SQL Server2000 SP3a was not found.
Please start the SQL Server2000 setup in the \Autorun\Autorun.exe directory from the CD supplied.
The WinCC instance for the Microsoft SQL server 2000 SP3a is intended for another language.
应该是要求装SQL Server 2000 SP3 For Wincc,可是网上很难下到,求高人分享一下,先谢了![/size]
11-07-26 17:26
没有
11-09-13 09:22
用电驴搜
11-12-22 12:48
