首页 传感器论坛
主题:Energy and Power Engineering《能源与动力工程》期刊导读
点击:391 回复:0
ISSN: 1949-243X (Print) 1947-3818 (Online).
《能源与动力工程》EPE免费下载网址: http://www.scirp.org/journal/epe.
Table of Contents(Vol.03 No.02, May 2011): (select part)
A repetitive-PI Current Controller for Boost Single Phase PFC Converters
Turki Kahawish Hassan
Studying Effect of Magnetizing Curve Nonlinearity Index on the Occurring Chaotic Ferroresonance Oscillation in Autotransformers
Hamid Radmanesh, Mehrdad Rostami, Jafar Khalilpour
PSS and SVC Controller Design using Chaos, PSO and SFL Algorithms to Enhancing the Power System Stability
Saeid Jalilzadeh, Reza Noroozian, Mahdi Sabouri, Saeid Behzadpoor
Application of Ant Colony Algorithm to the Analysis of Common Mode EMI Model of DC Motor
Jinfeng Liu, Xudong Wang, Jiang Nan
Energy Efficient Control of Three-Phase Induction Motor Drive
Hussein Sarhan
Economic Dispatch with Multiple Fuel Options Using CCF
R. Anandhakumar, S. Subramanian
Comparative Simulation Study between Gate Firing Units for HVDC Rectifier Based on CIGRE Benchmark Model
Bhaba Priyo Das, Neville Watson, Yonghe Liu
Bacterial Foraging Algorithm based Parameter Estimation of Three WINDING Transformer
Srikrishna Subramanian, Seeni Padma
EPE是一本由科研出版社出版的关于能源与动力工程领域最新进展的国际期刊。科研出版社(Scientific Research Publishing)作为开放读取(Open Access)的先行者、世界最大的开源期刊之一,目前已有180多种期刊及配套的电子版本,内容涵盖自然科学、农业科学、医药科学、工程与技术科学、社会科学等领域。多个期刊已被CAS,EBSCO,CAB Abstracts,ProQuest ,IndexCopernicus,Library of Congress,Gale, CSP等数据库全文或摘要收录。
期刊免费下载网址:http://www.scirp.org/journal/
  EHQ2VP1
11-07-26 14:17
