以下是用该仪器自带的软件 用串口监控到的向下发送的命令。由于没有接噪音计所以没有接收到数据。
1 [00000000] IRP_MJ_CREATE Port Opened - SoundMeter.exe
2 [00000002] IOCTL_SERIAL_SET_BAUD_RATE Baud Rate: 9600
3 [00000002] IOCTL_SERIAL_SET_LINE_CONTROL StopBits: 1, Parity: No, DataBits: 8
4 [00000017] IRP_MJ_WRITE Length: 0001, Data: 20
5 [00000037] IRP_MJ_WRITE Length: 0001, Data: 20
6 [00000057] IRP_MJ_WRITE Length: 0001, Data: 20
7 [00000077] IRP_MJ_WRITE Length: 0001, Data: 20
8 [00000097] IRP_MJ_WRITE Length: 0001, Data: 20
9 [00000117] IRP_MJ_WRITE Length: 0001, Data: 20
11-02-07 15:01
