是不是中断标志可以保留的, 但是电平触发就不可以了,
#include
#include
#define PA XBYTE[0xd1ff]
#define PB XBYTE[0xd2ff]
#define CON XBYTE[0xd6ff]
typedef unsigned char uchar;
typedef unsigned int uint;
uchar min,sec,flag,sec1,sec2;
uint ms,ms1,ms2;
code unsigned char tab[]={0xA0, 0xBB,0x62,0x2A,0x39,0x2C,0x24,0xBA,
0x20, 0x28, };//共阳数码管 0-9
void delay(unsigned int cnt)
while(--cnt);
display(uchar min,uchar sec)
uchar min_shi,min_ge,sec_shi,sec_ge;
min_shi=min/10;
min_ge=min%10;
sec_shi=sec/10;
sec_ge=sec%10;
PB=tab[min_shi];
PA=0xfe;
delay(200);
PB=tab[min_ge];
PA=0xfd;
delay(200);
PB=0x7f;
PA=0xf3;
delay(200);
PB=tab[sec_shi];
PA=0xef;
delay(200);
PB=tab[sec_ge];
PA=0xdf;
delay(200);
display_test(uchar zu,uchar sec,uchar ms)
uchar sec_ge,ms_bai,ms_shi;
ms_bai=ms/100;
ms_shi=ms/10%10;
sec_ge=sec%10;
PB=tab[zu];
PA=0xfe;
delay(200);
PB=0x7f;
PA=0xf5;
delay(200);
PB=tab[sec_ge];
PA=0xfb;
delay(200);
PB=tab[ms_bai];
PA=0xef;
delay(200);
PB=tab[ms_shi];
PA=0xdf;
delay(200);
void init()
TMOD=0x01;
TH0=0xFC;
TL0=0x18;
EA=1; //打开中断
ET0=1;
EX0=0;
IT0=1;IT1=1;
TR0=1;
CON=0x81;
void main()
init();
while(1)
{ if(flag==2)
if(sec1>sec2|(sec1==sec2&&ms1>ms2))
display_test(2,sec2,ms2);
else display_test(1,sec1,ms1);
else{
if((min==0&&sec==10)|(min==0&&sec==20))
PA=0x00;
PB=0x74;
EX0=1;
else display(min,sec);
IE0=0;
void int0(void) interrupt 0 using 1 //测反应速度
EX0=0;
flag++;
if(flag==1)
sec1=sec-10;
ms1=ms;
if(flag==2)
sec2=sec-20;
ms2=ms;
void tim0(void) interrupt 1 using 1
TH0=0xFC; //重新赋值
TL0=0x18;
ms++;
if (ms==1000)
ms=0;
sec++;
if(sec==60)
sec=0;
min++;
