首页 安防智能
主题:MITSUBISHI/三菱PLC F930GOT-BWD-C
点击:626 回复:0
LD-40PSU
LE-50PAU
LD-10PAU-A
LD-10PAU-B
LL-05ZX
LE-5AP-E
LD-30FTA
LD-30FTA-1AD
LD-FX
LD-05ZX
LE-30CTN/LE-30CTA
LE-40MTA-E
LE-40MTB-E
LE-40MD
LE-60EC
LX-005TD
LX-015TD
LX-030TD
LX-050TD
LX-100TD
LX-200TD
LX-005TD-909
LX-015TD-909
LX-030TD-909
LX-050TD-909
LX-100TD-909
LX-200TD-909
Cable for LX-TD
LX-05BRR
LM-10PD
LM-10TA
ZKG-5YN
ZKG-10YN
ZKG-20YN
ZKG-50YN
ZKB-0.06YN
ZKB-0.3YN
ZKB-0.6YN
ZKB-1.2XN
ZKB-2.5XN
ZKB-5XN
ZKB-10XN
ZKB-20XN
ZKB-40XN
ZKB-2.5HBN/HBN-C
ZKB-5HBN/HBN-C
ZKB-10HBN/HBN-C
ZKB-20HBN/HBN-C
ZKB-40HBN
ZKB-2.5WN
ZKB-5WN
ZKB-10WN
ZKB-20WN
ZKB-40WN
ZA-0.6Y
ZA-1.2Y1
ZA-2.5Y1
ZA-5Y1
ZA-10Y1
ZA-20Y1
ZA-40Y
ZX-0.3YN-24
ZX-0.3YN-80
ZX-0.6YN-24
ZX-0.6YN-80
ZX-1.2YN-24
ZX-1.2YN-80
ZX-2.5YH
ZX-2.5YS
ZX-5YH
ZX-5YS
ZHY-1.2A1
ZHY-2.5A
ZHY-5A1
ZHY-10A
ZHY-20A
ZHY-40A
ZHY-60A
ZHY-100A2
ZHY-0.03B
ZHY-0.08B
ZHY-0.3B
ZHY-0.6B
ZKG-5AN
ZKG-10AN
ZKG-20AN
ZKG-50AN
ZKG-100AN
ZKB-0.06AN
ZKB-0.3AN
ZKB-0.6AN
ZKB-1.2BN
ZKB-2.5BN
ZKB-5BN
ZKB-10BN
ZKB-20BN
ZKB-40BN
ZKB-1.2B4-909
ZKB-5B4-909
ZKB-10B2-909
ZKB-20B2-909
ZA-0.6A1
ZA-1.2A1
ZA-2.5A1
ZA-2.5A1-905
ZA-5A1 50 8,460
ZA-10A1 100
ZA-20A1 200
ZHA-0.6B
ZHA-1.2A1
ZHA-2.5A
ZHA-5A1
ZHA-10A
ZHA-20A
ZHA-40A
MITSUBISHI/三菱PLC FX3U-48MT-ES/A
FX3U-128MR-ES-A BASE UNIT WITH 64 INPUTS/64 RELAY OUTPUTS 12,040.00
FX3U-80MR-ES-A BASE UNIT WITH 40 INPUTS/40 RELAY OUTPUTS 8,950.00
FX3U-64MR-ES-A BASE UNIT WITH 32 INPUTS/32 RELAY OUTPUTS 7,740.00
FX3U-48MR-ES-A BASE UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 6,900.00
FX3U-32MR-ES-A BASE UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 5,970.00
FX3U-16MR-ES-A BASE UNIT WITH 8 INPUTS/8 RELAY OUTPUTS 5,150.00
FX3U-128MT-ES-A BASE UNIT WITH 64 INPUTS/64 TRANSISTOR OUTPUTS 12,410.00
FX3U-80MT-ES-A BASE UNIT WITH 40 INPUTS/40 TRANSISTOR OUTPUTS 9,230.00
FX3U-64MT-ES-A BASE UNIT WITH 32 INPUTS/32 TRANSISTOR OUTPUTS 7,980.00
FX3U-48MT-ES-A BASE UNIT WITH 24 INPUTS/24 TRANSISTOR OUTPUTS 7,110.00
FX3U-32MT-ES-A BASE UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 6,160.00
FX3U-16MT-ES-A BASE UNIT WITH 8 INPUTS/8 TRANSISTOR OUTPUTS 5,300.00
-[FX3UC SERIES BASE UNIT]
FX3UC-32MT-LT BASE UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 9,240.00
-[FX3U(C) ADAPTER BOARD]-
FX3U-232-BD RS-232C SERIAL PORT (1 CH) 470.00
FX3U-422-BD RS-422 SERIAL PORT (1 CH) 470.00
FX3U-485-BD RS-485 SERIAL PORT (1 CH) 470.00
FX3U-CNV-BD FX3U MODULE TRANSFORM UNIT 420.00
FX3U-USB-BD USB COMMUNICATION PORT (FOR ALL FX SERIES PLC) 850.00
-[FX3U(C) SPECIAL ADAPTER UNITS]
FX3U-2HSY-ADP 2 CHANNELS PULSE TRAIN OUTPUT 6,730.00
FX3U-4AD-ADP 4 CHANNELS A/D 2,070.00
FX3U-4AD-PT-ADP 4 CHANNELS TEMPERATURE INPUTS, PT TYPE 3,350.00
FX3U-4AD-TC-ADP 4 CHANNELS TEMPERATURE INPUTS, THERMAL COUPLE TYPE 3,350.00
FX3U-4DA-ADP 4 CHANNELS D/A 3,350.00
FX3U-4HSX-ADP 4 CHANNELS HIGH SPEED COUNTER 4,440.00
FX3U-232ADP RS232 COMMUNICATION MODULE 1,330.00
FX3U-485ADP RS485 COMMUNICATION MODULE 1,650.00
* The above prices are subject to change without prior notice FX3U-PLC-(1/2)
Mitsubishi
Programmable Controller
EFFECTIVE FROM: 1st March, 2006
PRICE LIST
MITSUBISHI MELSEC-FX SERIES PROGRAMMABLE CONTROLLERS
[FX3U, FX3UC Series]
(HK$)
MODEL DESCRIPTION UNIT PRICE
- [FX3U(C) SPECIAL UNITS]
FX3U-1PSU-5V DC 5V 1A POWER SUPPLY UNIT FOR FX3U SERIES 1,800.00
FX3U-4AD 4 CHANNELS A/D 2,490.00
FX3U-4DA 4 CHANNELS D/A 4,020.00
FX3U-7DM DISPLAY PANEL 1,470.00
FX3U-7DM-HLD DISPLAY PANEL HOLDER 670.00
FX3U-20SSC-H 2 CHL SSC-NET MODULE 7,210.00
FX3U-32BL BACKUP BATTERY FOR FX3UC CPU 610.00
FX3UC-1PS-5V DC 5V 1A POWER SUPPLY UNIT FOR FX3UC SERIES 1,800.00
FX3UC-4AD 4 CHANNELS A/D (16BIT) 2,490.00
-[MEMORY CASSETTE]
FX3U-FLROM-16 16K FLASH ROM MEMORY CASSETTE 520.00
FX3U-FLROM-64 64K FLASH ROM MEMORY CASSETTE 840.00
FX3U-FLROM-64L 64K PLC PROGRAM TRANSFER UNIT 1,260.00
* The above prices are subject to change without prior notice FX3U-PLC-(2/2)
Mitsubishi
EFFECTIVE FROM : 1st March, 2006
PRICE LIST
[FX2N, FX2NC Series]
(HK$)
-[FX2N SERIES BASE UNIT]
FX2N-128MR-001 BASE UNIT WITH 64 INPUTS/64 RELAY OUTPUTS 10,120.00
FX2N-80MR-001 BASE UNIT WITH 40 INPUTS/40 RELAY OUTPUTS 7,030.00
FX2N-64MR-001 BASE UNIT WITH 32 INPUTS/32 RELAY OUTPUTS 6,280.00
FX2N-48MR-001 BASE UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 5,490.00
FX2N-32MR-001 BASE UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 5,180.00
FX2N-16MR-001 BASE UNIT WITH 8 INPUTS/8 RELAY OUTPUTS 4,150.00
FX2N-128MT-001 BASE UNIT WITH 64 INPUTS/64 TRANSISTOR OUTPUTS 10,330.00
FX2N-80MT-001 BASE UNIT WITH 40 INPUTS/40 TRANSISTOR OUTPUTS 7,180.00
FX2N-64MT-001 BASE UNIT WITH 32 INPUTS/32 TRANSISTOR OUTPUTS 6,410.00
FX2N-48MT-001 BASE UNIT WITH 24 INPUTS/24 TRANSISTOR OUTPUTS 5,600.00
FX2N-32MT-001 BASE UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 5,290.00
FX2N-16MT-001 BASE UNIT WITH 8 INPUTS/8 TRANSISTOR OUTPUTS 4,240.00
-[FX2NC SERIES BASIC UNIT]
FX2NC-96MT BASE UNIT WITH 48 INPUTS/48 TRANISITOR OUTPUTS 8,760.00
FX2NC-64MT BASE UNIT WITH 32 INPUTS/32 TRANISITOR OUTPUTS 6,610.00
FX2NC-32MT BASE UNIT WITH 16 INPUTS/16 TRANISITOR OUTPUTS 4,230.00
FX2NC-16MT BASE UNIT WITH 8 INPUTS/8 TRANISITOR OUTPUTS 3,220.00
-[FX2N SERIES EXTENSION UNIT]
FX2N-48ER EXTENSION UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 4,190.00
FX2N-48ET EXTENSION UNIT WITH 24 INPUTS/24 TRANSISTOR OUTPUTS 4,190.00
FX2N-32ER EXTENSION UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 3,060.00
FX2N-32ET EXTENSION UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 3,060.00
FX2N-16EX EXTENSION UNIT WITH 16 INPUT 1,120.00
FX2N-16EYR EXTENSION UNIT WITH 16 RELAY OUTPUTS 1,270.00
FX2N-16EYT EXTENSION UNIT WITH 16 TRANSISTOR OUTPUTS 1,270.00
FX2N-8ER EXTENSION UNIT WITH 4 INPUTS/4 RELAY OUTPUTS 900.00
FX2N-8EX EXTENSION UNIT WITH 8 INPUTS 750.00
FX2N-8EYR EXTENSION UNIT WITH 8 RELAY OUTPUTS 900.00
FX2N-8EYT EXTENSION UNIT WITH 8 TRANSISTOR OUTPUTS 900.00
-[FX2NC SERIES EXTENSION UNIT]
FX2NC-32EX EXTENSION UNIT WITH 32 INPUTS 2,410.00
FX2NC-32EYT EXTENSION UNIT WITH 32 TRANSISTOR OUTPUTS 2,560.00
FX2NC-16EX EXTENSION UNIT WITH 16 INPUTS 1,360.00
FX2NC-16EYT EXTENSION UNIT WITH 16 TRANSISTOR OUTPUTS 1,660.00
FX2NC-16EX-T EXTENSION UNIT WITH 16 INPUTS 1,080.00
FX2NC-16EYR-T EXTENSION UNIT WITH 8 RELAY OUTPUTS 1,320.00
* The above prices are subject to change without prior notice FX2N-PLC-(1/2)
Mitsubishi
PRICE LIST
[FX2N. FX2NC Series]
(HK$)
-[FX2N SPECIAL FUNCTION UNIT]
FX2N-2AD 2 CHANNELS A/D 1,740.00
FX2N-2DA 2 CHANNELS D/A 2,100.00
FX2N-2LC 2 CHANNELS TEMPERATURE CONTROL BLOCK 4,450.00
FX2N-4AD 4 CHANNELS A/D 2,310.00
FX2N-4AD-PT 4 CHANNELS TEMPERATURE INPUTS, PT TYPE 3,270.00
FX2N-4AD-TC 4 CHANNELS TEMPERATURE INPUTS, THERMAL COUPLE TYPE 3,270.00
FX2N-4DA 4 CHANNELS D/A 3,270.00
FX2N-5A 4 CHANNEL A/D, 1 CHANNEL D/A 3,400.00
FX2N-8AD 8 CHANNELS A/D 7,630.00
FX2N-1HC HIGH SPEED COUNTER BLOCK (1 CH) 3,170.00
FX2N-1PG-E PULSE TRAIN OUTPUT BLOCK (1 CH-100KHz) 4,270.00
FX2N-10GM 1 AXIS POSITION CONTROL UNIT 4,630.00
FX2N-10PG PULSE TRAIN OUTPUT BLOCK (1 CH-1MHz) 5,250.00
FX2N-20GM 2 AXIS POSITION CONTROL UNIT 8,860.00
E-20TP-E-SET0 PROGRAMMER FOR FX2N-10GM AND FX2N-20GM 5,260.00
E-GM-200CAB 2 M CABLE FOR SERVO DRIVER 360.00
E-GMJ2-200CAB1A 2 M CABLE FOR MR-J2 SERVO DRIVER 850.00
FX2N-1RM-E-SET PROGRAMMABLE CAM MODULE INCLUDE RESOLVER 8,770.00
F2-720RSV RESOLVER 3,360.00
F2-RS-5CAB EXTENSION CABLE FOR FX2N-RS-5CAB 710.00
FX2N-RS-5CAB NAL CABLE BETWEEN FX2N-1RM AND F2-720RSV 620.00
FX-PCS-VPS/WIN-E GM GRAPHICAL PROGRAMMING SOFTWARE 1,070.00
FX2N-16CCL-M COMPUTER AND COMMUNICATION LINK MASTER BLOCK 2,700.00
FX2N-16LNK-M REMOTE I/O SYSTEM MASTER BLOCK 2,160.00
FX2N-32ASI-M AS-INTERFACE MODULE 4,230.00
FX2N-32CCL COMPUTER AND COMMUNICATION LINK INTERFACE BLOCK 2,490.00
FX2N-64CL-M CC-LINK/LT MASTER BLOCK 2,560.00
FX2N-20PSU POWER SUPPLY UNIT (24DC, 2A) 1,670.00
FX2N-232IF RS-232 COMMUNICATION BLOCK (1 CH) 4,480.00
FX2N-CNV-IF EXTENSION CABLE CONVERTOR (FX2 TO FX2N) 400.00
-[FX2N ADAPTER BOARD]
FX2N-8AV-BD MANUALLY ADJUSTABLE POTENTIOMETER INPUT BOARDS 400.00
FX2N-232-BD RS-232C SERIAL PORT (1 CH) 400.00
FX2N-422-BD RS-422 SERIAL PORT (1 CH) 400.00
FX2N-485-BD RS-485 SERIAL PORT (1 CH) 400.00
FX2N-CNV-BC EXTENSION CABLE CONVERTOR 400.00
FX2N-CNV-BD FX0N MODULE TRANSFORM UNIT 400.00
FX2NC-232-ADP RS232 COMMUNICATION MODULE 1,230.00
FX2NC-485-ADP RS485 COMMUNICATION MODULE 1,550.00
FX2NC-CNV-IF INTERFACE ADAPTER 400.00
FX2N-PLC-(2/2)
Mitsubishi
PRICE LIST
[FX1N, FX1S Series]
(HK$)
-[FX1N SERIES BASE UNIT]
FX1N-60MR-001 BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS 4,680.00
FX1N-40MR-001 BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,030.00
FX1N-24MR-001 BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,330.00
FX1N-14MR-001 BASE UNIT WITH 8 INPUTS/6 RELAY OUTPUTS 2,310.00
FX1N-60MT-001 BASE UNIT WITH 36 INPUTS/24 TRANSISTOR OUTPUTS 4,800.00
FX1N-40MT-001 BASE UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS 4,130.00
FX1N-24MT-001 BASE UNIT WITH 14 INPUTS/10 TRANSISTOR OUTPUTS 3,400.00
FX1N-14MT-001 BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 2,400.00
-[FX1NC SERIES BASIC UNIT]
FX1NC-16MT BASE UNIT WITH 8 INPUTS/8 TRANISITOR OUTPUTS 2,550.00
FX1NC-32MT BASE UNIT WITH 16 INPUTS/16 TRANISITOR OUTPUTS 3,550.00
-[FX1S SERIES BASE UNIT]
FX1S-30MR-001 BASE UNIT WITH 16 INPUTS/14 RELAY OUTPUTS 2,870.00
FX1S-20MR-001 BASE UNIT WITH 12 INPUTS/8 RELAY OUTPUTS 2,350.00
FX1S-14MR-001 BASE UNIT WITH 8 INPUTS/6 RELAY OUTPUTS 1,850.00
FX1S-10MR-001 BASE UNIT WITH 6 INPUTS/4 RELAY OUTPUTS 1,580.00
FX1S-30MT-001 BASE UNIT WITH 16 INPUTS/14 TRANSISTOR OUTPUTS 2,940.00
FX1S-20MT-001 BASE UNIT WITH 12 INPUTS/8 TRANSISTOR OUTPUTS 2,410.00
FX1S-14MT-001 BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 1,900.00
FX1S-10MT-001 BASE UNIT WITH 6 INPUTS/4 TRANSISTOR OUTPUTS 1,620.00
-[FX1N ADAPTER BOARD]
FX1N-1DA-BD 1 CHANNEL D/A 1,210.00
FX1N-2AD-BD 2 CHANNELS A/D 1,210.00
FX1N-2EYT-BD EXT. BOARD WITH 2 TRANSISTOR OUTPUTS 500.00
FX1N-4EX-BD EXT. BOARD WITH 4 INPUTS 500.00
FX1N-8AV-BD MANUALLY ADJUSTABLE POTENTIOMETER INPUT BOARDS 400.00
FX1N-232-BD RS-232C SERIAL PORT (1 CH) 400.00
FX1N-422-BD RS-422 SERIAL PORT (1 CH) 400.00
FX1N-485-BD RS-485 SERIAL PORT (1 CH) 400.00
FX1N-CNV-BD FX0N MODULE TRANSFORM UNIT 400.00
-[MEMORY CASSETTE]
FX1N-EEPROM-8L PLC PROGRAM TRANSFER UNIT 710.00
* The above prices are subject to change without prior notice FX1N/S-PLC-(1/1)
Mitsubishi
PRICE LIST
[FX1N, FX1S, FX2N, FX2NC, FX3U, FX3UC Series]
(HK$)
-[FX0N SERIES EXTENSION UNITS]
FX0N-40ER EXTENSION UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 2,980.00
FX0N-40ET EXTENSION UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS 2,980.00
-[FX0N SPECIAL UNITS]
FX0N-3A 2 CHANNEL A/D, 1 CHANNEL D/A 2,330.00
FX0N-30EC EXTENSION CABLE (30CM) 290.00
FX0N-65EC EXTENSION CABLE (60CM) 350.00
FX0N-32NT-DP PROFIBUS-DP INTERFACE UNIT 2,420.00
-[PROGRAMMING SOFTWARE, TOOLS & CABLE]
F2-40BL BACKUP BATTERY FOR FX CPU 530.00
FX-2PIF 2 TO 1 INTERFACE FOR FX-20P-E, DATA ACCESS UNIT AND FX PLC 4,490.00
FX-20P-ADP-KIT OFFLINE PROGRAMMING ADAPTOR 1,480.00
FX-20P-CADP UNIVERSAL ADAPTOR CABLE 0.3M 250.00
FX-20P-E-SET0 HANDY PROGRAMMING PANEL FOR FX0S,FX0N,FX2N SERIES CPU 2,740.00
FX-20P-RWM ROM WRITER FOR FX-20P-E 3,380.00
FX-485PC-IF RS232/RS485 CONVERTER 1,360.00
FX-USB-AW USB TO RS422 CONVERTER 2,200.00
GX-DEVELOPER-C PROGRAM SOFTWARE, WINDOW VERSION (GPPW/LLT) - CHIN. 6,300.00
GX-DEVELOPER-E PROGRAM SOFTWARE, WINDOW VERSION (GPPW/LLT) - ENG. 6,300.00
SC09 RS232/RS422 INTERFACE UNIT 2,000.00
- [REMOTE TERMINAL BLOCK &CABLE]
FX-16E-TB TERMINAL BOX FOR 16 INPUTS 330.00
FX-32E-TB TERMINAL BOX FOR 32 INPUTS 560.00
FX-16EYR-TB TERMINAL BOX FOR 16 RELAY OUTPUTS 1,450.00
FX-16EYS-TB TERMINAL BOX FOR 16 TRAIC OUTPUTS 1,770.00
FX-16EYT-TB TERMINAL BOX FOR 16 TRANSISTOR OUTPUTS 1,450.00
FX-16EYT-H-TB TERMINAL BOX FOR 16 TRANSISTOR OUTPUTS, HIGH CURRENT 2,010.00
FX-16E-150CAB 1.5M CONNECTION CABLE 360.00
FX-16E-300CAB 3 M CONNECTION CABLE 400.00
FX-16E-500CAB 5 M CONNECTION CABLE 570.00
FX-16E-150CAB-R 1.5M CONNECTION CABLE 410.00
FX-16E-300CAB-R 3 M CONNECTION CABLE 450.00
FX-16E-500CAB-R 5 M CONNECTION CABLE 570.00
-[MEMORY CASSETTE]
FX-EEPROM-4 4K EEPROM MEMORY CASSETTE 490.00
FX-EEPROM-8 8K EEPROM MEMORY CASSETTE 620.00
FX-EEPROM-16 16K EEPROM MEMORY CASSETTE 1,020.00
FX-EPROM-8 8K EPROM MEMORY CASSETTE 490.00
FX2N-ROM-E1 INVERTER INSTRUCTION CASSETTE 1,460.00
FX2NC-EEPROM-16 16K EEPROM MEMORY CASSETTE (FX2NC) 1,210.00
联系人:陈玉红  13538233502
QQ 1303347839  邮箱 yhyj2008@163.com
10-09-27 16:00
