首页 工控软件 工控软件
主题:求救:求CRC-CCITT计算软件
点击:1005 回复:0
如题,其算法如下,求可计算出校验码的程序(exe格式)
//--说明--
//j=5 --有效数据(0x7856341252H) 字节长度为5
//s[0]-s[j-1]
//s[j]-s[j+1]  上述数据CRC校验码为(0xB135H)
//i,CrcA,CrcB,CrcC --临时变量
/*/--程序--*/
CrcA = s[0];
CrcB = s[1];
CrcC = s[2];
for (i=2;i CRC(&CrcA,&CrcB,&CrcC);
CrcC = s[i+1];
s[j] = CrcA;
s[j+1] = CrcB;
//这里以CRC-CCITT标准生成多项式。CRC-CCITT是一个17位生成多项式
//G=[1 0001 0000 0010 0001],用多项式形式表示为G(x)=x16+x12
//+x5+1,由它产生的检验码R的二进制位数是16位(2字节)。
const unsigned char ha00[256] ={
0x00,0x10,0x20,0x30,0x40,0x50,0x60,0x70,0x81,0x91,0xA1,0xB1,0xC1,0xD1,0xE1,0xF1,
0x12,0x02,0x32,0x22,0x52,0x42,0x72,0x62,0x93,0x83,0xB3,0xA3,0xD3,0xC3,0xF3,0xE3,
0x24,0x34,0x04,0x14,0x64,0x74,0x44,0x54,0xA5,0xB5,0x85,0x95,0xE5,0xF5,0xC5,0xD5,
0x36,0x26,0x16,0x06,0x76,0x66,0x56,0x46,0xB7,0xA7,0x97,0x87,0xF7,0xE7,0xD7,0xC7,
0x48,0x58,0x68,0x78,0x08,0x18,0x28,0x38,0xC9,0xD9,0xE9,0xF9,0x89,0x99,0xA9,0xB9,
0x5A,0x4A,0x7A,0x6A,0x1A,0x0A,0x3A,0x2A,0xDB,0xCB,0xFB,0xEB,0x9B,0x8B,0xBB,0xAB,
0x6C,0x7C,0x4C,0x5C,0x2C,0x3C,0x0C,0x1C,0xED,0xFD,0xCD,0xDD,0xAD,0xBD,0x8D,0x9D,
0x7E,0x6E,0x5E,0x4E,0x3E,0x2E,0x1E,0x0E,0xFF,0xEF,0xDF,0xCF,0xBF,0xAF,0x9F,0x8F,
0x91,0x81,0xB1,0xA1,0xD1,0xC1,0xF1,0xE1,0x10,0x00,0x30,0x20,0x50,0x40,0x70,0x60,
0x83,0x93,0xA3,0xB3,0xC3,0xD3,0xE3,0xF3,0x02,0x12,0x22,0x32,0x42,0x52,0x62,0x72,
0xB5,0xA5,0x95,0x85,0xF5,0xE5,0xD5,0xC5,0x34,0x24,0x14,0x04,0x74,0x64,0x54,0x44,
0xA7,0xB7,0x87,0x97,0xE7,0xF7,0xC7,0xD7,0x26,0x36,0x06,0x16,0x66,0x76,0x46,0x56,
0xD9,0xC9,0xF9,0xE9,0x99,0x89,0xB9,0xA9,0x58,0x48,0x78,0x68,0x18,0x08,0x38,0x28,
0xCB,0xDB,0xEB,0xFB,0x8B,0x9B,0xAB,0xBB,0x4A,0x5A,0x6A,0x7A,0x0A,0x1A,0x2A,0x3A,
0xFD,0xED,0xDD,0xCD,0xBD,0xAD,0x9D,0x8D,0x7C,0x6C,0x5C,0x4C,0x3C,0x2C,0x1C,0x0C,
0xEF,0xFF,0xCF,0xDF,0xAF,0xBF,0x8F,0x9F,0x6E,0x7E,0x4E,0x5E,0x2E,0x3E,0x0E,0x1E
const unsigned char la00[256] ={
0x00,0x21,0x42,0x63,0x84,0xA5,0xC6,0xE7,0x08,0x29,0x4A,0x6B,0x8C,0xAD,0xCE,0xEF,
0x31,0x10,0x73,0x52,0xB5,0x94,0xF7,0xD6,0x39,0x18,0x7B,0x5A,0xBD,0x9C,0xFF,0xDE,
0x62,0x43,0x20,0x01,0xE6,0xC7,0xA4,0x85,0x6A,0x4B,0x28,0x09,0xEE,0xCF,0xAC,0x8D,
0x53,0x72,0x11,0x30,0xD7,0xF6,0x95,0xB4,0x5B,0x7A,0x19,0x38,0xDF,0xFE,0x9D,0xBC,
0xC4,0xE5,0x86,0xA7,0x40,0x61,0x02,0x23,0xCC,0xED,0x8E,0xAF,0x48,0x69,0x0A,0x2B,
0xF5,0xD4,0xB7,0x96,0x71,0x50,0x33,0x12,0xFD,0xDC,0xBF,0x9E,0x79,0x58,0x3B,0x1A,
0xA6,0x87,0xE4,0xC5,0x22,0x03,0x60,0x41,0xAE,0x8F,0xEC,0xCD,0x2A,0x0B,0x68,0x49,
0x97,0xB6,0xD5,0xF4,0x13,0x32,0x51,0x70,0x9F,0xBE,0xDD,0xFC,0x1B,0x3A,0x59,0x78,
0x88,0xA9,0xCA,0xEB,0x0C,0x2D,0x4E,0x6F,0x80,0xA1,0xC2,0xE3,0x04,0x25,0x46,0x67,
0xB9,0x98,0xFB,0xDA,0x3D,0x1C,0x7F,0x5E,0xB1,0x90,0xF3,0xD2,0x35,0x14,0x77,0x56,
0xEA,0xCB,0xA8,0x89,0x6E,0x4F,0x2C,0x0D,0xE2,0xC3,0xA0,0x81,0x66,0x47,0x24,0x05,
0xDB,0xFA,0x99,0xB8,0x5F,0x7E,0x1D,0x3C,0xD3,0xF2,0x91,0xB0,0x57,0x76,0x15,0x34,
0x4C,0x6D,0x0E,0x2F,0xC8,0xE9,0x8A,0xAB,0x44,0x65,0x06,0x27,0xC0,0xE1,0x82,0xA3,
0x7D,0x5C,0x3F,0x1E,0xF9,0xD8,0xBB,0x9A,0x75,0x54,0x37,0x16,0xF1,0xD0,0xB3,0x92,
0x2E,0x0F,0x6C,0x4D,0xAA,0x8B,0xE8,0xC9,0x26,0x07,0x64,0x45,0xA2,0x83,0xE0,0xC1,
0x1F,0x3E,0x5D,0x7C,0x9B,0xBA,0xD9,0xF8,0x17,0x36,0x55,0x74,0x93,0xB2,0xD1,0xF0
void CRC(uchar *a,uchar *b,uchar *c) {
*c = la00[*a] ^ *c;
*a = ha00[*a] ^ *b;
*b = *c;
哪位大侠,请发到我邮箱casy1987@126.com
最后修改:2010/8/20 15:52:19
10-08-18 16:42
