首页 串口通信 串口通信
主题:大家帮忙,看看我的VB、omron通讯程序
点击:2588 回复:2
下面是我试编的程序,我往DM0000中写入FFFF,然后将PLC的响应显示在Text1中。运行时,程序没有报告错误,但是在Text1中没有任何反应。请大家帮忙看看。谢谢
Private Sub Command1_Click()
Dim outdata, L, fcs1, i, FCS, instring, fcs2, fcs3 As String
 outdata = "@00WD0000FFFF"
 L = Len(outdata)
 fcs1 = 0
 For i = 1 To L
   fcs1 = fcs1 Xor Asc(Mid(outdata, i, 1))
 Next i
 FCS = Hex(fcs1)
 Text1.Text = FCS
 MSComm1.Output = outdata + "FCS " + "*" + Chr$(13)
 Do
    DoEvents
 Loop Until MSComm1.InBufferCount >= 10
 instring = MSComm1.Input
 Text2.Text = instring
 fcs2 = 0
 For i = 1 To Len(instring) - 4
 fcs2 = fcs2 Xor Asc(Mid(instring, i, 1))
 Next i
 fcs3 = Hex(fcs2)
 If fcs3 = Mid(instring, Len(instring) - 3, 2) Then
  Text3.Text = "right"
 Else
  Text3.Text = "wrong"
 End If
End Sub
Private Sub Form_Load()
 MSComm1.CommPort = 1
 MSComm1.Settings = "9600,e,7,2"
 MSComm1.InputLen = 0
 MSComm1.PortOpen = True
End Sub
04-10-26 11:32
找个串口调试软件发16进制
4030305453313233343537362A0D
看返回的是不是下面的东西!
[@00TS1234576*+Chr(13)]
要是的话,连路,格式就没有设置错。
看看你应该是fcs那错了,要是其他没有错的话!
04-10-26 23:35
请说得详细一些。
04-10-27 10:02
