Car Air-conditioning - MUST READ!!
汽車的空調----必讀!!
No wonder more folks are dying from cancer than ever before. We wonder where this stuff comes from but here is an example that explains a lot of the cancer causing incidents. Hmmm. Many people are in their cars first thing in the morning and the last thing at night, 7 days a week. As I read this, it makes me feel guilty and ill. Please pass this on to as many people as possible. Guess its not too late to make some changes.
怪不得比起從前,有越來越多鄉親死於癌症,在我們都還不清楚癌症是從哪兒來之際,有個實例顯示出許多癌症都是意外發生的。嗯,許多人早上第一件事和晚上最後一件事都是待在汽車裡,一周7天。當我讀到這個,感到又難過又愧疚。請盡可能地把這訊息傳給大家,希望還來得及做些改變。
Please do NOT turn on A/C as soon as you enter the car. Open the windows after you enter your car and turn ON the AC after a couple of minutes.
進入車內不要馬上打開空調,先打開車窗通風幾分鐘,才打開空調。
Here's why:
以下是原因:
According to a research, the car dashboard, sofa, air freshener emit Benzene, a Cancer causing toxin
(carcinogen - take time to observe the smell of heated plastic in your car).
根據研究,汽車的儀表板。沙發。空氣濾清器會釋放“苯”,產生毒素而致癌。(致癌物質——花一點時間去觀察你的車里的塑膠製品高溫時產生的氣味。)
In addition to causing cancer, Benzene poisons your bones, causes anemia and reduces white blood cells.
Prolonged exposure will cause Leukemia, increasing the risk of cancer. Can also cause miscarriage.
除了致癌之外,”苯“還會侵蝕我們的骨骼,造成貧血和降低白血球數量。長期曝露其中會導致白血病,大大增加罹癌的風險,也可能導致流產。
Acceptable Benzene level indoors is 50mg per sq.ft. A car parked indoors with windows closed will contain 400-800 mg of Benzene.
苯”每平方英尺的可接受水平為50毫克。若停車在室內又窗戶緊閉,則產生400-800毫克的“苯”。
If parked outdoors under the sun at a temperature above 60 degrees F, the Benzene level goes up to 2000-4000 mg, 40 times the acceptable level.
若停在戶外大太陽下溫度超過 60 ℉ ( 15.5 ℃ ),“苯”就上升至2000-4000毫克,超出允許量的40倍!
People who get into the car, keeping windows closed will inevitably inhale, in quick succession, excessive amounts of the toxin.
人們只要進入車內而又車窗緊閉,將會無法避免快速連續地吸入過量的毒素。
Benzene is a toxin that affects your kidney and liver.. What's worse, it is extremely difficult for your body to expel this toxic stuff.
“苯”是那種會影響你的腎臟和肝臟的毒素,更糟糕的是,你的身體想把這種有毒物質排擠出去是極度困難的。
So friends, please open the windows and door of your car - give time for interior to air out -dispel the deadly stuff - before you enter.
所以朋友們,進入汽車之前,請把你車子的門窗打開,給點時間讓車內的空氣--致命的東西排出。
