首页 工控英语角
主题:美国电视上的一个记忆力测试游戏
点击:1500 回复:2
A memory test on TV program in the State, the idea is to look at the following 1 to 12 for 2 minutes then close it and count from 1 to 12 without mess up. Can you do that?
One Hen
Two Ducks
Three cackling geese
Four corpulent porpoises
Five pairs of Donald Pheezer’s favorite tweezers
Six limerick oysters
Seven hundred Macedonian warriors dressed in full battle array
Eight apathetic sympathetic diabetic old men with canes
Nine brass monkeys from the ancient sacred secret crypts of Egypt
Ten Theophilous thistles, the successful thistle sifter, while sifting a sift-full of unsifted thistles thrust three thousand thistles through the thick of his thumb
Eleven slimy scaly snakes slithering slowing along the sandy shore
Twelve lyrical spherical diabolical denizens of the deep who haul stall around the corner of the quo of the quay of the quivery, all at the same time.
10-07-28 10:23
I Can't do it
10-09-08 16:27
I Can't do it,TOO。
10-12-24 18:02
