首页 DCS论坛 DCS论坛
主题:国际电工委员会(IEC)标准规范
点击:5932 回复:3
国际电工委员会(IEC)标准规范
STD CODE Description 标准代码 描述
IEC 60034-1 ROTATING ELECTRICAL MACHINES - PART 1: RATING AND PERFORMANCE 动设备 - 第1部分:额定功率和性能参数
IEC 60534-1 INDUSTRIAL-PROCESS CONTROL VALVES Part 1: Control valve terminology and general considerations
IEC 60534-2-5 Industrial-process control valves – Part 2-5: Flow capacity – Sizing equations for fluid flow through multistage control valves with interstage recovery
IEC 60770_3 Transmitters for use in industrial-process control systems,Part 3: Methods for evaluation of intelligent transmitters
IEC 61131-3 PROGRAMMABLE CONTROLLER - PROGRAMMING LANGUAGE 可编程控制器-编程语言
IEC 61131-3 PPT TRAINING DOCUMENT
IEC 61131-8 Programmable controllers – Part 8: Guidelines for the application and implementation of programming languages
IEC 61158-2 Digital data communication for measurement and control – Fieldbus for use in industrial control systems – Part 2 : Physical Layer specification
IEC 61158-3 Digital data communication for measurement and control – Fieldbus for use in industrial control systems – Part 3 : Data Link Layer service definition
IEC 61158-4 Digital data communication for measurement and control – Fieldbus for use in industrial control systems – Part 4 : Data Link Layer protocol specification
IEC 61158-6 Digital data communication for measurement and control – Fieldbus for use in industrial control systems – Part 6 : Application Layer protocol specification
IEC 61285 Industrial process Control-Safety of Analyzer Houses
IEC 61499-1 Function Blocks for industrial-process measurement and control systems - Part 1 Architecture
IEC 61499-2 Function Blocks for industrial-process measurement and control systems - Part 2 Software tools requirements
IEC 61499-3 Function blocks for industrial-process measurement and control systems - Part 3: Technical report- tutorial information
IEC 61508 Functional safety and IEC 61508 A basic guide
IEC 61511-2 Functional safety – Safety instrumented systems for the process industry sector – Part 2: Guidelines for the application of IEC 61511-1
IEC 61784-1 Digital data communications for measurement and control - Part 1: Profile sets for continuous and discrete manufacturing relative to fieldbus use in industrial control systems
IEC 61804 Function Blocks for Process Control Training Powerpoint Package zip 过程控制功能模块培训
IEC 61804-1 Function Blocks for process control – Part 1: Overview of system aspects
IEC 61804-2 IEC 61804-2: Function blocks (FB) for process control – Part 2: Specification of FB concept and Electronic Device Description Language (EDDL)
IEC 61987-1 Industrial-process measurement and control – Data structures and elements in process equipment catalogues – Part 1: Measuring equipment with analogue and digital output
IEC 65-309 Activities During the FACTORY ACCEPTANCE TEST (FAT), SITE ACCEPTANCE TEST (SAT), and SITE INTEGRATION TEST (SIT) for AUTOMATION SYSTEMS in the Process Industry
IEC 65-310 Electrical And Instrumentation Loop Check 电气和仪表回路检测
IEC 79-7 ELECTRICAL APPARATUS FOR EXPLOSIVE GAS ARMOSPHERES PART7: INCREASED SAFETY "E" 爆炸性气体中的电气设备 第7部分:增安型
IEC 79-10 ELECTRICAL APPARATUS FOR EXPLOSIVE GAS ARMOSPHERES PART10: CLASSIFICATION OF HAZARDOUS AREAS 爆炸性气体中的电气设备 第10部分:危险区域分类
IEC 10790 Measurement of fluid flow in closed conduits — Guidance to the selection, installation and use of Coriolis meters (mass flow,density and volume flow measurements) AMENDMENT 1: Guidelines for gas measurement
该帖内容不符合相关规定!
04-09-28 20:49
最好能下载。
04-09-29 09:07
该帖内容不符合相关规定!
04-09-29 12:16
