1.
ncu
上的七段显示码:
表示“an error was identified in the cyclical operation.”
一个错误是确定的周期性运作。
0
表示“real mode may have been switched to protected mode.”
真正的模式可能已经切换到保护模式。
1
表示“start of download from the pcmcia card.”
开始下载pcmcia卡。
(number with decimal point 号码小数点)
表示:“the number of the module that has just been downloaded appears on the status display.”
在一些模块,刚刚被下载上的状态显示。
2
表示“download from the pcmcia card has ended successful.”
下载pcmcia卡已经结束成功。
3
表示“the debug monitor is initialized.”
调试监测初始化。
4
表示“operating system was downloaded successfully.”
操作系统成功下载。
5
表示“operating system has started up.”
操作系统启动。
6
表示“nck software is initialized.”
nck
软件初始化。
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=108704&Name=zwmwcj
