首页 电脑编程
主题:VB超级经典源代码!!!
点击:4858 回复:14
禁止使用 alt-tab 或 ctrl-alt-del
private declare function enablewindow lib user32 (byval hwnd as integer, byval abool as integer) as integer
private declare function iswindowenabled lib user32 (byval hwnd as integer) as integer
private declare function getmenu lib user32 (byval hwnd as integer) as integer
private declare function findwindow lib user32 alias findwindowa (byval lpclassname as string, byval lpwindowname as string) as long
private declare function systemparametersinfo lib user32 alias systemparametersinfoa (byval uaction as long, byval uparam as long, byval lpvparam as any, byval fuwinini as long) as long
private taskbarhwnd as long
private istaskbarenabled as integer
private taskbarmenuhwnd as integer
禁止或允许使用 alt-tab
sub fasttaskswitching(benabled as boolean)
dim x as long, bdisabled as long
bdisabled = not benabled
x = systemparametersinfo(97, bdisabled, cstr(1), 0)
end sub
禁止使用ctrl-alt-del
public sub disabletaskbar()
dim ewindow as integer
taskbarhwnd = findwindow(shell_traywnd, )
if taskbarhwnd  0 then
ewindow = iswindowenabled(taskbarhwnd)
if ewindow = 1 then
istaskbarenabled = enablewindow(taskbarhwnd, 0)
end if
end if
end sub
允许使用ctrl-alt-del
public sub enabletaskbar()
if istaskbarenabled = 0 then
istaskbarenabled = enablewindow(taskbarhwnd, 1)
end if
end sub
禁止 ctrl+alt+del
声明:
const spi_screensaverrunning = 97
private declare function systemparametersinfo lib user32 alias _
systemparametersinfoa (byval uaction as long, byval uparam as long, _
使用:
禁止
dim pold as boolean
call systemparametersinfo(spi_screensaverrunning, true, pold, 0)
开启
dim pold as boolean
call systemparametersinfo(spi_screensaverrunning, false, pold, 0)
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=103666&Name=jczwfy
09-10-21 20:26
迷糊了
09-10-21 21:33
能实现一个什么功能
09-10-21 22:32
用不来;
09-10-22 09:39
该帖内容不符合相关规定!
09-10-23 11:44
by
????????????????bumingbai
09-12-02 09:01
看不懂呀
09-12-03 12:55
该帖内容不符合相关规定!
09-12-04 14:37
对牛弹琴
10-05-02 22:28
呵呵~~~
说的不太详细,其实就是用VB屏蔽一些系统功能键
许多人都没看明白楼主发的是什么
10-07-16 14:49
上一页下一页
