首页 单片机论坛
主题:高难度单片机程序,烦请看看!
点击:3673 回复:11
目的:写出这个程序的功能,还有工作原理,并请对程序进行改善。
#include "reg52.H"
#include "intrins.h"
#define uchar unsigned char
#define uint unsigned int
sbit P0_0 = 0x80;
sbit P0_1 = 0x81;
sbit P0_2 = 0x82;
sbit P0_3 = 0x83;
sbit P0_4 = 0x84;
sbit P0_5 = 0x85;
sbit P1_5 = 0x95;
sbit P2_7 = 0xA7;
sbit IntSignal=0xB5;
sfr  WDT_CONTR=0xe1;
sbit CS=0xe9;
uchar Addr;
uint msCount;
uchar SignalTimeOut;
uchar SignalTime;
uint ProcLEDTime;
uchar State_p2;
bit erro=0;
bit StateTime=0;
bit RSState=0;
uint ClockMs,ClockS;
uint TempClockS;
uchar S_State,M_State,E_State;
uchar Move_State;
uchar State;
bit Erro_ri=0;
bit SignalState;
bit rise;
bit ProcStop;
uchar code StateTab[12]={0xbe,0xde,0xee,0xf6,
      0xbd,0xdd,0xed,0xf5,
      0xbb,0xdb,0xeb,0xf3,};
/*__________________________
读取P2口状态
void Statecode(uchar State_code)
switch (State_code)
{  case 0xbe: State_p2=0; break;
   case 0xde: State_p2=1; break;
   case 0xee: State_p2=2; break;
   case 0xf6: State_p2=3; break;
   case 0xbd: State_p2=4; break;
   case 0xdd: State_p2=5; break;
   case 0xed: State_p2=6; break;
   case 0xf5: State_p2=7; break;
   case 0xbb: State_p2=8; break;
   case 0xdb: State_p2=9; break;
   case 0xeb: State_p2=10; break;
   case 0xf3: State_p2=11; break;
   default: break;
void mDelay(uint Dat)
uint j;
for (;Dat>0;Dat--)
 {for (j=42;j>0;j--);WDT_CONTR=0x38;}
void Delay10m()  //10分钟延时,600秒
ClockMs=0;
ClockS=0;
while(ClockS<600) ;
故障状态
void Error()
ET0=0;
P2=0xff;
mDelay(12);
P0_0=1;
erro=1;
P0_4=1;
P0_5=0;
while(1)
 P0_3=~P0_3;
 mDelay(500);
P2_7
void SignalCheck()
if(SignalTimeOut>25) Error(); //20ms内监测
else erro=0;
rise=0;
if(SignalState!=P2_7)
 SignalState=P2_7;
 rise=SignalState;
 SignalTimeOut=0;
if(rise) SignalTime+=1;
if(P0_4&&(SignalTime==100)){P0_4=0;SignalTime=0;}
if((!P0_4)&&(SignalTime==50)){P0_4=1;SignalTime=0;}
/*_________________________________
P0_3
void ProcLED()
if(ProcStop) {P0_3=1;return;}
ProcLEDTime+=1;
if(ProcLEDTime==2000) {P0_3=~P0_3;ProcLEDTime=0;}
void Timer0() interrupt 1 using 0
TL0=0x9a;  //
TH0=0xfe;       //
SignalTimeOut+=1;
msCount+=1;
ClockMs+=1;
if(ClockMs==1000){ClockMs=0;ClockS+=1;}
SignalCheck();  //检测上升沿
   ProcLED();
WDT_CONTR=0x38;
void StateProc(uchar delay)
uchar i;
if(delay)
 for(i=5;i>0;i--) { msCount=0;while(msCount<60000);} //5分钟延时
else
 msCount=0;
 while(msCount<20000);  //20秒延时
while(!rise);//检上升沿到来
msCount=0;
while(msCount<1);//延1ms
P2=0xff;//置高
   msCount=0;
while(msCount<10);//2008-03-04修10ms
/*while(!rise);//检上升沿到*/
   P2=StateTab[State];//执行
void IntProc()
if(IntSignal)return;
E_State= P1>>5;
ProcStop=0;
while(!(IntSignal&&(State==M_State)))
 if(IntSignal)
   if(State     {State+=1;StateProc(0);}
 else
  if(State==E_State) while(!IntSignal);
  else {State-=1;StateProc(0);}
ProcStop=1;
等待延时
void mDelay0(register uchar n)
for(n;n>1;n--) WDT_CONTR=0x38;
发送地址
void SendsAddr()
WDT_CONTR=0x38;
TB8=0;
CS=0;
mDelay0(10);
P0_1=0;
SBUF=Addr;
while(!TI);
TI=0;
mDelay0(15);
SM2=0;
CS=1;
mDelay0(5);
发送数据
void SendsData()
uchar temp;
WDT_CONTR=0x38;
   TB8=0;
CS=0;
mDelay0(10);
temp=P2;
Statecode(temp);
   if(!erro) SBUF=State_p2;
else SBUF=13;
while(!TI);
TI=0;
mDelay0(15);
SM2=1;
CS=1;
mDelay0(5);
执行P0口命令
void D_Move()
mDelay(1000);
WDT_CONTR=0x38;
if(State>Move_State)
{   ProcStop=0;
 Erro_ri=0;
 do
  State-=1;
  StateProc(0);
 while(State>Move_State);
       ProcStop=1;
else if(State    {
 Erro_ri=0;
 ProcStop=0;
 do
  State+=1;
  StateProc(0);
 }while(State  ProcStop=1;
 else { Erro_ri=0; StateProc(0); }
 mDelay(1000);
串口中断
void Uart() interrupt 4 using 1
if(RI==1)
{   uchar temp;
    uchar temp0;
    uchar Sbuftemp;
    RI=0;
 Sbuftemp=SBUF;
 Erro_ri=1;
 mDelay0(15);
 if(SM2==0)
   temp=Sbuftemp&0x0f;
  if(temp>11) { RSState=0; Move_State=11; }
  else
  {   Addr=P1&0xc0;
     temp0=Sbuftemp&0xc0;
     if((temp0==Addr)||(temp0==0x00)) {  RSState=1; Move_State=temp; }
  SendsData();
 else
  Addr=P1&0xc0;
  if(Sbuftemp==Addr) SendsAddr();
  else
   SM2=1;
   P0_1=1;
   CS=1;
 else TI=0;
void main()
 P2=0xff;P0=0xff;P1=0xff;P3=0xff;
mDelay(1000);  //启动延迟时间
   SCON=0x90;
   PCON=0x00;
SM2=1;
   TH0=0xfe;  //
TL0=0xa2;    //晶振4.194304 MHz  1ms定时
TMOD=0x01;      //
TR0=1;
IP=0x10;
    EA=1;
    ES=1;
 ET0=1;
   Addr=P1&0xc0;
SignalState=P2_7;
WDT_CONTR=0x38;
S_State=7;  //启动端口
State=S_State;
while(!rise);
P0_0=0;
ProcStop=0;
P2=StateTab[State];
do
 Erro_ri=0;
 State+=1;
 StateProc(0);
while(State<11);
ProcStop=1;
   Delay10m();  //10分钟
   /*mDelay(2000);*/
M_State=11-((P1>>3)&0x3);
ProcStop=0;
while(State>M_State)
 Erro_ri=0;
 State-=1;
 StateProc(0);
ProcStop=1;
retu: mDelay(5000);
while(Erro_ri&RSState) D_Move();
ClockMs=0;
ClockS=0;
while(ClockS<14400)        //延时4小时,14400秒
   if(Erro_ri&RSState) goto retu;
 if(!IntSignal)
  mDelay(1000);
  if(!IntSignal)
   TempClockS=ClockS;
   IntProc();
   ClockS=TempClockS;
Erro_ri=0;
S_State=P1&0x07;
if(State>S_State)
 ProcStop=0;
 do
  State-=1;
  StateProc(1);
 while(State>S_State);
       ProcStop=1;
else if(State    {
 ProcStop=0;
 do
  State+=1;
  StateProc(1);
 else {  if(Erro_ri&RSState) goto retu; StateProc(1); }
while(1) if(Erro_ri&RSState) goto retu;
09-07-31 13:36
变频器程序吧?
09-07-31 21:15
看看。。。。
12-03-23 16:49
围观:的确是高难度程序;非常的难以理解写程序人的“高深写法”;发程序人可要好好写出工作原理来;
表情
12-03-26 08:16
有人讲解一下不
16-06-13 14:39
为什么发这么难的难我们
16-06-13 17:37
表示看不懂,自学过,半途而废。
16-06-13 20:41
嗯  我就是来看看而已  然后表示看不懂
18-08-08 11:10
[QUOTE]void Delay10m()  //10分钟延时,600秒
ClockMs=0;
ClockS=0;
while(ClockS<600) ;
}[/QUOTE]
这个是不是死循环?
其他的程序我全都懂,就是不知道什么意思
18-09-27 23:12
虽然我看不懂,但是我还是进来看看
18-10-07 21:50
上一页下一页
