首页 单片机论坛
主题:请大家看看这个程序哪地方不对
点击:1210 回复:2
#include           //1
unsigned char dis0=0x99;      //2
unsigned char dis1=0xb0;      //3
unsigned char dis2=0xa4;      //4
unsigned char dis3=0xf9;      //5
/*=====================6===============*/
void delay(void)                   //7
{                                        //8
      unsigned int i,j;             //9
      for(i=0;i<2;i++)            //10
      {                                 //11
             for(j=0;j<121;j++) //12
             {;}                        //13
      }                                 //14
}                                        //15
//=====================16===========
void main(void)                   //17
{                                        //18
while(1)                              //19
      {                                 //20
P0=dis0;                       //21
P2=0xfe;                      //22
delay();                        //23
      P0=dis1;                       //24
      P2=0xfd;                      //25
delay();                        //26
P0=dis2;                       //27
P2=0xfb;                      //28
delay();                        //29
P0=dis3;                       //30
      P2=0xf7;                      //31
delay();                    &, amp;nb, sp;   //32
      }                                 //33
}                                        //34
09-05-17 16:06
删除这段程序    &, amp;nb, sp;   //32 就OK
09-05-20 13:45
呵呵,是想让数码管循环显示,1,2,3,4啊!楼上说的对,这段程序是没什么错误的,想必多出的那一点是手误吧!如果不能显示的话,可能是硬件连接上有问题吧,p0口接了数码要加上拉电阻的,还有可能你显示的时间间隔可能得调一调啊!
09-05-22 22:09
