首页 PLC论坛 西门子SIEMENS
主题:超级菜鸟请教,帮忙解释一下程序!
点击:2355 回复:12
第一个
      A     M    120.7
     AN    DB40.DBX    0.0
     AN    DB40.DBX    0.4
     AN    DB40.DBX    0.5
     R     M    120.7
     S     DB40.DBX    0.0
     A(
     O     DB40.DBX    0.4
     O     DB40.DBX    0.5
     A     DB40.DBX    0.0
     R     DB40.DBX    0.0
     L     W#16#6
     T     DB40.DBW   10
     CALL  FB     8 , DB50
      IN0  :='S'
      IN1  :=DB40.DBX0.0
      IN2  :=DB40.DBX0.1
      IN3  :=272
      IN4  :=42
      IN5  :=DB43.DBW702
      IN6  :=DB40.DBW10
      IN7  :=
      IN8  :='X'
      IN9  :=
      IN10 :=
      IN11 :=
      IN12 :=
      OUT13:=DB40.DBX0.4
      OUT14:=DB40.DBX0.5
      OUT15:=DB40.DBW12
     A     DB40.DBX    0.4
     JCN   M001
     L     DB40.DBW    6
     +     1
     T     DB40.DBW    6
     NOP   0
     NOP   0
     NOP   0
     JU    M002
M001: A     DB40.DBX    0.5
     JCN   M003
     L     DB40.DBW    8
     +     1
     T     DB40.DBW    8
     SET
     =     M    120.6
     SET
     =     M    120.7
     NOP   0
     NOP   0
     NOP   0
     L     0
     L     DB40.DBW   12
     ==I
     JC    M002
     T     DB40.DBW   14
     JU    M002
M003: L     0
     L     DB40.DBW   12
     ==I
     JC    M002
     T     DB40.DBW   14
     SET
     =     M    120.6
     SET
     =     M    120.7
     NOP   0
     NOP   0
     NOP   0
M002: CLR
     L     DB43.DBW  700
     T     MW   156
09-05-07 10:29
第二个
SET
     =     DB41.DBX    0.0
     CALL  FB     7 , DB70
      IN0  :=DB41.DBX0.0
      IN1  :=
      IN2  :=272
      IN3  :=43
      IN4  :=DB43.DBW704
      OUT5 :=
      OUT6 :=
      OUT7 :=
      OUT8 :=
      OUT9 :=
      OUT10:=DB41.DBX0.4
      OUT11:=DB41.DBX0.5
      OUT12:=DB41.DBW10
      OUT13:=DB41.DBW12
     A     DB41.DBX    0.4
     JCN   M001
     L     DB41.DBW    6
     +     1
     T     DB41.DBW    6
     SET
     =     M    120.3
     L     DB41.DBW   10
     T     DB41.DBW    4
     JU    M002
M001: A     DB41.DBX    0.5
     JCN   M003
     L     DB41.DBW    8
     +     1
     T     DB41.DBW    8
     L     0
     L     DB41.DBW   12
     ==I
     JC    M002
     T     DB41.DBW   14
     JU    M002
M003: L     0
     L     DB41.DBW   12
     ==I
     JC    M002
     T     DB41.DBW   14
     SET
     =     M    120.4
M002: CLR
     SET
     =     M    120.7
09-05-07 10:30
不胜感激!!!
09-05-07 10:31
发梯形图上来,直观一些。
09-05-07 11:52
都是簡單指令,您自己不去翻翻STL手冊?
長篇大論給您講簡單指令有何意思呢?此為其一。
其二是這樣的無注釋的絕對地址恐怕您是從PLC上載的吧,無任何工藝了解,無任何注釋以及IO分配,您讓我們來給您當翻譯?
源程式呢?
Regards
09-05-07 13:05
自己看看吧,或自己转成梯图,对地址,对工艺吧。
09-05-07 15:08
太长了,不知道设备工艺,光是知道语句的意思,也是不好理解的
09-05-07 21:02
大家就体谅一下这个超级菜鸟吧,可是楼主你也要把相关的资料上传呀,要不大家都不知怎么帮你了!
09-05-07 22:10
没有办法解释
09-05-09 21:44
转成STL大家都可以帮你解决的啊,问问题也好办啦
09-05-14 21:35
上一页下一页
