#include
#include
#define uchar unsighed char
#define unit unsighed int
static float fKP=0.3,fTI=20,fTD=0,fKD=0.5,fSampT=0.010;
static float ek_1=0,ek_2=0;
static float deltaUdk_1=0;
static float u=0;
float DeltaPID(float ek)
float deltaUp;
float deltaUi;
float deltaUd;
deltaUp=fKP*(ek-ek_1);
deltaUi=fKP*fSampT*ek/fTI;
deltaUd=fTD/(fKD*fSampT+fTD)*(deltaUdk_1+fKP*fKD*(ek-2*ek_1+ek_2));
ek_2=ek_1;
ek_1=ek;
deltaUdk_1=deltaUd;
u=u+deltaUp+deltaUi+deltaUd;
显示的错误是"STARTUP.obj"
TO "mm"
*** FATAL ERROR L210: I/O ERROR ON INPUT FILE:
EXCEPTION 0021H: PATH OR FILE NOT FOUND
FILE: C:\KEIL\C51\LIB\C51FPS.LIB
Target not created
