首页 单片机论坛
主题:MCP3201做了一个12位串行A/D转换电路
点击:1119 回复:0
请教各位大侠:最近用MCP3201做了一个12位串行A/D转换电路,可是怎么修改程序,总是输出0FFFH,不知问题出在哪?望支招
MCP3201: SETB CS
               MOV 29H,#15 ;
               NOP
NXTBIT: CLR AD_CLK ;X,X,NULL,D11,D10,D9...D0
               NOP
               CLR CS ; CS low to startconversion or keep low till done
               NOP
               SETB AD_CLK ; raise the clock
               NOP
               MOV C,DAT ; put data into C flag
               RLC A ; shift C into Acc (A/D low bits)
               XCH A,15H                 ; get ADRESH byte
               RLC A ; shift C into Acc (A.D high bits)
               XCH A,15H ; get low bits back into Acc for next loop
               DJNZ 29H,NXTBIT
               MOV 16H,A ; put A into ADRESL
               ANL 15H,#0FH ; mask off unwanted bits (x,X,X,Null)
               SETB CS ; set CS hi to end conversion
最后修改:2009-3-18 20:02:45
09-03-18 19:57
