首页 PLC论坛 西门子SIEMENS
主题:S7-300STL语句问题求助!什么意思?
点击:2368 回复:1
SET
     SAVE
     =     L      0.1
     L     #IU
     T     #U_MON
     L     0.000000e+000
           JCN   A7d0
     T     #IN
     SET
     =     #CSF
     JU    A7d1
A7d0: L     #IU
     L     2.764800e+004
     >R
     JCN   A7d2
     T     #IN
     SET
     =     #CSF
     JU    A7d1
A7d2: L     #IU
     T     #IN
     CLR
     =     #CSF
A7d1: CLR
     A     #BIPOLAR
     JCN   A7d3
     L     #IN
     L     #K2
     /R
     L     #RANGE_HI
     TAK
     T     LD     2
     TAK
     L     #RANGE_LOW
     -R
     L     LD     2
     *R
     L     #RANGE_LOW
     +R
     T     #U
     JU    A7d4
A7d3: L     #IN
     L     #K1
     -R
     L     #K2
     TAK
     T     LD     2
     TAK
     L     #K1
     -R
     L     LD     2
     TAK
     /R
     L     #RANGE_HI
     TAK
     T     LD     2
     TAK
     L     #RANGE_LOW
     -R
     L     LD     2
     *R
     L     #RANGE_LOW
     +R
     T     #U
A7d4: L     #U
     L     #U_AH
     >R
     JCN   A7d5
     SET
     =     #QH_ALM
     JU    A7d6
A7d5: CLR
     =     #QH_ALM
A7d6: L     #U
     L     #U_AL
           JCN   A7d7
     SET
     =     #QL_ALM
     JU    A7d8
A7d7: CLR
     =     #QL_ALM
A7d8: L     #U
     L     #U_WH
     >R
     JCN   A7d9
     SET
     =     #QH_WRN
     JU    A7da
A7d9: CLR
     =     #QH_WRN
A7da: L     #U
     L     #U_WL
           JCN   A7db
     SET
     =     #QL_WRN
     JU    A7dc
A7db: CLR
     =     #QL_WRN
A7dc: CLR
     A     L      0.1
     SAVE
     BE 表情
04-06-11 15:31
axg
好象是模拟量转换程序,有什么上下限报警,比例,转换输出等
最好有输入输出的声明,才易看
04-06-12 20:32
