首页 工控英语角
主题:火电英语词汇分类
点击:3915 回复:1
火电英语词汇分类[/b][/b]
~[/b]锅炉部分[/b]~[/b]
亚临界压力锅炉    subcritical pressure boiler
燃煤锅炉       coal-fired boiler
启动锅炉       start-up boiler
炉墙               furnace wall
管束(排)    tube bundle
管屏               tube platen
下降管            downcomer
上升管            riser
省煤器管       economizer tube
再热器管       reheater tube
过热器管       superheated tube
蛇形管            coil
吊挂管            supporting tube
水冷壁管       water wall tube
饱和蒸汽管    saturated steam pipe
水冷壁            water wall
鳍片管            finned tube, fin tube, gilled tube
联箱               header
锅炉本体       boiler proper
锅炉机组       boiler unit
炉膛               boiler framework
燃烧器            furnace
燃烧室            combustion chamber
油枪               oil gun torch
风门               damper
管板               tube plate
煤粉管道       pulverized coal piping
过热器            superheater
沸点               boiling temperature
吹灰器            soot blower
包墙过热器    wall enclosure superheater
再热器            reheater
炉膛容积       furnace volume
再热器冷段    primary reheater
汽水分离器    steam separator, moisture separator
再热器热段    final reheater
省煤器            economizer
空气预热器    air preheater
安全门            safety valve
防暴门            explosion vent
检查孔            inspection hole
三通阀            three-way valve
事故喷水阀    emergency water spray valve
锅炉排污       blowdown
大板梁            plate girder, upper beam
灰斗               ash hopper
空气压缩机    air compressor
混合器            mixer
磨煤机            coal pulverizer, coal mill
一次风机       primary air fan
送风机            forced draft fan, force fan
人孔门            man hole
引风机            induced draft fan, induced fan
膨胀补偿节    expansion joint
原煤斗            raw coal bunker, raw coal silo
结渣               lagging
煤粉仓            pulverized coal bunker
看火孔            observation hole
水循环            water circulation
风道               air duct
除尘器            dust collector, precipitator
伸缩节
灰渣泵            ash pump, slag pump
风道               air duct
轴封泵            shaft sealing pump
伸缩节            expansion joint
灰浆泵            ash slurry pump
风管道            air piping
保温材料       heat-insulating material
除灰管道       ash piping
稳定燃烧       stable combustion
烟囱               chimney, stack
支吊架            supports and hangers
燃烧               combustion
水压试验       hydraulic test
负压               negative pressure
点火               ignition
正压               positive pressure
着火点            firing point, ignition temperature
冷风               cold air
锅炉上水       boiler water filling
热风               hot air
点火用油       fuel oil for ignition
停炉               boiler shutdown
熄火               fire-off
~[/b]汽轮机部分[/b]~[/b]
汽轮机            steam turbine
高压汽缸       high-pressure(hp) cylinder
凝汽式汽轮机       condensing steam turbine
中压汽缸       intermediate-pressure(ip) cylinder
亚临界压力汽轮机subcritical pressure turbine
低压汽缸       low-pressure(lp) cylinder
汽缸台板(底板)cylinder sole pin
汽轮机转子    turbine rotor
汽封               steam seal gland, steam sealing
叶轮               blade disc
轴承支架       bearing stoll, bearing bracket
叶片               blade, bucket
主油泵            main oil pump
喷嘴               nozzle
备用油泵       emergency bearing oil pump
固定螺钉       dowel
交流润滑油泵       ac lube oil pump
注油器            oil injector
直流润滑油泵       dc lube oil pump
喷油嘴            oil nozzle
高位油箱       head oil tank, elevated oil tank
杠杆               lever
凝汽器            condenser
轴            shaft
管板               tube plate
弹簧               spring
热水井            hot well
凝汽器喉部    condenser throat
凝结水泵       condensate pump
泵壳               pump casing
低压加热器    low-pressure feed water heater
高压加热器    high-pressure feed water heater
除氧器            deaerator
除氧水箱       deaerated water tank
除盐水箱       demineralized water tank
汽动给水泵    steam-driven feed water pump
前置水泵       booster pump
给水泵            feed water pump
疏水泵            drain pump
水室               water chamber
疏水扩容器    drain flash tank
挡板               baffle plate
封头               end cover
真空泵            vaccum pump
工业水泵       industrial water pump, service water pump
收球网            ball screen
胶球泵            rubber ball recirculating pump
主蒸汽系统    main steam system
支撑斜钢       supporting wedge
再热蒸汽系统       reheat steam syetem
自然通风冷却塔    natural draft cooling tower
抽汽系统       extraction steam system
主蒸汽管道    main steam piping, live steam piping
轴封               shaft seal
真空系统       vaccum system
凝结水系统    condensate system
再热蒸汽管道       reheat steam system
给水系统       feed water system
循环水系统    circulating water system
供油系统       oil supply system
工业水系统    industrial water system, service water system
抽汽管道       steam extraction pipe
供汽联箱       steam header
压缩空气管道       compressed air piping
疏水管道       drain water piping
氢气管道       hydrogen piping
凝结水管道    condensate piping
循环水管道    circulating water piping
冷却水管道    cooling water piping
给水管道       feed water piping
润滑油管       lube oil piping
除盐水管道    demineralized water piping
旁路门            bypass valve
减温水管道    attemperating water piping
球型阀            globe valve
再循环水管道       recirculating water piping
闸板阀            gate valve
排水管道       water discharge piping
疏水阀            drain valve
高压主汽门    high-pressure main stop valve
蝶阀               butterfly valve
中压主汽门    intermediate pressure main stop valve
转速               rotating speed, revolution
热效率          thermal efficiency, heat efficiency
过热度            superheat degree
新蒸汽压力    initial steam pressure, live steam pressure
温差               temperature difference
开启               opening
再热蒸汽冷段压力cold reheated steam pressure
关闭               closing
再热蒸汽热段压力hot reheated steam pressure
启动               starting-up
再热蒸汽热段温度hot reheated steam temperature
停止               shutting down
再热蒸汽冷段温度cold reheated steam temperature
检查               inspection, examination
低压缸排汽流量    low-pressure cylinder exhaust steam flow
巡检               routing inspection
再热蒸汽流量       reheated steam flow
主蒸汽流量    steam flow
法兰加热       flange heating
螺栓加热       bolt heating
正常状态       normal condition
清洗               cleaning
操作               operation
酸洗               acid cleaning, pickling
解体               disassembly
组装               assembly
检修               maintenance
拆开               dismantling
汽缸扣盖       cylinder covering
变形               deformation
毛刺               burr
裂纹               crack
锈蚀               rusting
壁厚               wall thickness
同心               concentricity
找正               centering
垫铁               iron cushion, packing iron plate, adjusting pad
找中心            alignment
台板               sole plate
天车               turbine hall overhead crane
管束               tube bundle
汽机基座       turbine pedestal
流量               flow
抽汽量            steam extraction capacity
海水               sea water
保温材料       heat insulating material
防腐               anti-corrosion
~[/b]电气部分[/b]~[/b]
发电机            electric generator, generator
一次电压       primary voltage
发电机定子    generator stator
二次电压       secondary voltage
发电机转子    generator stator
一次绕组       primary winding
主变压器       main transformer
二次绕组       secondary winding
工作变压器    operating transformer
高压线路       high-voltage line
备用变压器    standby transformer
导电环            conducting ring
开关               switch
零电位            zero potential
按钮               button
漏电               electric leakage
电压               voltage
母线               bus, busbar
电流               current
测电笔            test pencil
电流强度       current intensity
验电器            electroscope
电阻               resistance
匝数               number of turns
电功率            electric power
屏蔽接地       shield earthing
电压表            voltmeter
延迟时间       delay time
伏特               volt
绝缘               insulation
千伏               kilovolt
相序               phase order, phase sequence
电流表            ammeter, amperemeter
相电压            phase voltage
安培               ampere
电阻测量       resistance measurement
千瓦小时       kilowatt-hour
电压测量       voltage measurement
电位计            potentiometer
电流测定       current measurement
功率表            wattmeter
时间测定       time measurement
瓦特               watt
明线               open wire, open conductor
千瓦               kilowatt
暗线               concealed wire, concealed conductor
兆瓦               megawatt
照明线路       lighting line
赫兹               hertz
控制               control
转速表            speedometer
输电               transmission
千伏安            kilovoltampere
带电               live, electrified
欧姆               ohm
原理图            schematic diagram
通风               ventilation, draft
电力系统       electric power system
避雷针            lightning rod, lightning conductor
控制台            control board
电源               power source, power supply
电负荷            power load
交流电源       ac power source
功率损失       power loss
直流电源       dc power source
供电               power supply
不停电电源    uninterrupted power supply(ups)
发电               power generation
强电               strong current
操作人            operator
弱电               weak current
监护人            guardian
继电器            relay
通信               communication
锁闭装置       locking device
电话机            telephone set
断路器            breaker, circuit breaker
电话号            telephone number
接触器            contactor
电缆               cable
插件               plug-in unit, insertion piece
信号               signal
保护接地       protective earthing
连接器            connector
保护罩            protective cover, protective housing
单元               unit
熔断器            cutout, fusible cutout
主机               main machine
电缆               cable
系统               system
电缆芯            cable core
电子元件       electronic
单元控制室    unit control room
故障               fault
配电室            switch room, distribution board room
正常               normal
频率               frequency
异常               abnormal
毫安表            millammeter
告警               alarm
毫伏表            millvoltmeter
输入               input
电子计算机    electronic computer
输出               output
架空线路       overhead line
信号状态       signal status
布线               wiring
结束               end
合上               switch-on
测试               test
重拨               redial
拨号               dial
直拨               direct dialing
断开               switch-off
~[/b]化学部分[/b]~[/b]
化学加药处理      chemical treatment feeding
酸洗               acid cleaning
自来水            raw water, crude water
软化水            softened water
除盐水            demineralized water
过滤               filtration
去矿物质水    demineralized water
除气               deaeration
再生               regeneration
污染              pollution
腐蚀               corrosion
结垢               scaling
水垢               scale
离子交换树脂       ion exchange resin
石灰               lime
混床               mixed bed
并联               in parallel
串联               in series
溶解箱            dissolving tank
溶液箱            solution tank
取样装置       sampling device
溶质               solute
溶剂               solvent
~[/b]仪表与控制部分[/b]~[/b]
温度计            thermometer
鼠标器            mouse
驱动器            drive
压力开关       pressure switch
键盘               keyboard
标准大气压力       standard atmosphere
存储器            storage, memory
锅炉压力       boiler pressure
延时               time delay
风压               air pressure
在线               on line
喷嘴               nozzle
离线               off line
给水流量       feed water flow
扩展               extension
蒸汽流量       steam flow
扫描               scan
阻尼器            snubber, damper
刷新               update
总线               bus
阻塞               clogging
画面               graphic display
传输速率       transmission rate
存储               storage
源程序            source program
文字标题       literal title
滤波器            filter
图象信息       graphic information
返回               return
中间变量       intermedium variable
中断               interrupt
操作指导       operation guide
保留               retain
信息共享       information sharing
删除               delect
吹扫               purge
节点               node
点火器            igniter
发送               send, transmit
灵敏度            sensitivity
接收               receive
精确度            accuracy
数据库            data base
灵活性            flexibility
调制解调器    modulator-demodulator(modem)
可扩展性       expandability
兼容               compatibility
分散度            dispersity
按钮               button, pushbutton
工作时间       up time
确认               acknowledgement
故障时间       down time
复位               reset
仪表            measuring instrument
开关               switch
~[/b]燃料部分[/b]~[/b]
输煤栈桥       coal belt conveyor gallery
起吊孔            lifting hole
漏斗               hopper
燃煤品种       category of coal
输煤皮带       conveyor belt
结焦性            coking property
皮带速度       belt velocity
结渣性            slagging property
皮带宽度       belt width
固定碳            fixed carbon
驱动功率       driving power
设计煤种       design coal
机车               locomotive
闪点               flash point
煤气               gas
~[/b]综合部分[/b]~[/b]
图纸              drawing
合金               alloy
平面图            plan, plan view
电焊               electric welding
校对               check
电焊条            welding electrode
审核               review
焊丝               welding wire
批准               approve
焊接               welding
数量               quantity
气孔               blowhole
重量               weight
咬边               undercut
材料               material
焊口裂纹       weld seam crack
图号               drawing number
坡口加工       edge preparation
测量               measurement
应力               stress
尺寸               size, dimension
着色剂            colorants, coloring agent
中心距            center distance
蠕变               creep
加工余量       finish allowance, machine allowance
垫片               gasket, pad, shim
表面               surface
石棉垫            asbestos pad, babbit cushion
水平               level
中心孔            center bore, center hole, center opening
检验               test, check, examination
装配               assembly, installation
圆度               ellipticity
剖面               section, cross-section
~[/b]附加部分[/b]~[/b]
长度               length
缺陷处理       defect treatment
面积               area
铭牌               nameplate
体积(容积)       volume
技术检验记录       technical check record
质量               mass
技术资料       technical information, technical data
重量               weight
事故               accident, emergency
能量               energy
发电量            power generation, generated energy
形状               shape
设备缺陷       equipment defector
方形               square
扩建工程       extension project
圆形               round
复印               copying
半径               radius
装订               binding
直径               diameter
出版               publication
周长               circumference, perimeter
主厂房布置图       main machine building arrangement drawing
参数               parameter
主厂房            main machine hall, main power building
温度               temperature
汽机房            turbine hall, turbine house
压力               pressure
除氧间(除气间)deaerator bay
真空               vacuum
锅炉房            boiler hall, boiler house
流量               flow, flow capacity
烟囱               chimney, stack
压缩               compression
灰场               ash yard
膨胀               expansion
渣场               slag yard
起动               start-up, starting
灰坝               ash dam
停机               shutdown, outage, stoppage
近期               near future, short-term
检测               detection, test
远期               future, long-term
并联               parallel connection
底层               ground floor
串联               series connection
地下室            basement
气体               gas
梁            beam
液体            liquid
柱            column, pillar
固体               solid
楼板               floor slab
标高               elevation
平台               platform
调试               test and adjustment
扶梯               stair
试运行            trial operation
地面               ground
保温               heat insulation, thermal insulation
设备基础       equipment foundation
油漆               paint
煤场               coal yard
灭火器            fire extinguisher
采暖               heating
运行               operation, running
照明               lighting
业主               owner
通风               ventilation
合同               contract
安装               erection, installation
价格               price
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=64548&Name=yi-tang
08-10-16 17:22
学习一下,谢谢
10-01-13 11:30
