step 1: drive mechanism
the sizing process begins by identifying the drive mechanism to be used
obtaining the design specifics such as the inertias, efficiencies and dimensions of all components
identify mechanical constraints such as torque and force limits that must not be exceeded
the following drive mechanisms are available:
1.
rotary
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/rotary.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image001.gif
[/URL]
2.
belt & pulley
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/beltandpulley.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image002.gif
[/URL]
3.
conveyor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/conveyor.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image003.gif
[/URL]
4.
dual stage conveyor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/dualstageconveyor.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image004.gif
[/URL]
5.
ball screw
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/ballscrew.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image005.gif
[/URL]
6.
rack & pinion
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/rackandpinion.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image006.gif
[/URL]
7.
dual stage rack & conveyor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/dualstagerackandconveyor.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image007.gif
[/URL]
8.
pin roller
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/pinroller.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image008.gif
[/URL]
9.
winder center driven
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/windercenter.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image010.gif
[/URL]
10.
winder surface driven
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/windersurface.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image011.gif
[/URL]
11.
linear motor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/linearmotordrivemechanics.htm]
http://blog.gkong.com/mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/drivemechanics_files/image009.gif
[/URL]
然后是选择不同的机械结构计算相应机械惯量,以及各类极限值。
此篇文章从博客转发
原文地址:
Http://blog.gkong.com/more.asp?id=64227&Name=lightwhite
