16进制10进制互换程序
unsigned char d[10]; //用于显示的10位显示缓存
//16进制to10进制输出子程序:显示数据,起始位,结束位,有无小数点
void output(unsigned long dd,unsigned char s,unsigned char e,unsigned char dip) {
unsigned long div;
unsigned char tm[8],i,j;
div=10000000;
for (i=0;i10进制互换程序
unsigned long div;
div=10000000;
for (i=0;i
#include
#include
#define e 8
#define p 9
#define l 10
sbit led=p3^2;
sbit p27=p2^7;
sbit p26=p2^6;
sbit p36=p3^6;
sbit p37=p3^7;
sbit rst=p3^3;
sbit ale=p3^5;
sbit vpp=p3^4;
bit b_break;
unsigned int adds;
// 13.8ms
void int_t0(void) interrupt 1 {
th0=-100;
b_break=1;
void wait(unsigned char w) {
unsigned int t=w*184;
b_break=0;
tl0=-t%256-1;th0=-t/256;
while (b_break==0) {}
void nop(void) {
_nop_();_nop_();_nop_();_nop_();
unsigned char command(void) {
th0=-100;b_break=0;
while (ri==0) {if (b_break==1) return(0);}
ri=0;
return(sbuf);
void earsure(unsigned char cpu) {
switch (cpu) {
case 1: //89c51
case 2:rst=p26=1;p27=p36=p37=0;nop();vpp=1;nop();
ale=0;wait(110);ale=1;nop();
break;
case 3:
case 4:break;
case 5:
case 6:break;
void program(unsigned char cpu) {
unsigned int bdata adds=0;
unsigned char d;
switch (cpu) {
case 1: //89c51
case 2:
p36=p37=1;rst=1;
while (1) {
th0=-100;b_break=0;
while (ri==0) {if (b_break==1) return;}
ri=0;
d=sbuf;
//address
p0=adds%256;
p2=adds/256;
p27=1;
//data
p1=d;
nop(); //48clcl
//vpp
vpp=1;
nop(); //48clcl
//ale
ale=0;
wait(1);//100us
ale=1;
nop(); //10us
vpp=0;
nop(); //48clcl
p27=0;
nop(); //48clcl
p1=0xff;
th0=-100;b_break=0;
while (d!=p1) {if (b_break==1) return;} //data polling
sbuf=d;
adds++;
break;
case 3:
case 4:
case 5:
case 6:break;
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=61988&Name=zhaosiyun
