首页 PLC论坛 三菱Mitsubishi
主题:求助:三菱 PLC MELSEC-F2-40M的相关资料
点击:3720 回复:10
    在下最近跳槽,接手工作后发现大量设备资料残缺不全,掺啊~~~~~没办法~~~~~~~~~~~~~
   只能自己慢慢补了,解决一样是一样。
    跪求:MELSEC-F2-40M的相关资料。特别是编程用的软件,以及PG所用数据线的图纸等~~~~~~~~~~
    各位大侠请帮个忙啊!!!!!
04-04-12 19:53
F2是三菱公司上世纪80年代出的产品,早该扔了!
有点骨气,不要动不动就跪求!
04-04-12 21:30
引用 三菱电机 在 2004-4-12 21:30:00 发言【内容省略】
F1,F2現役中狀況良好的多的是,都扔嗎?
人家有問題才來本網求助,你這不是幫襯本網,你是在扯後腿...第一次警告你,若不想發言,或是言不由衷,可以不說,不講,不寫.
不指點回答,叫人扔東西,再噱人一頓,虧你真作生意的!就如此回答問題嗎?人家沒骨氣也強過浙江中創販售公開下載的說明檔案與軟體,更何況CRACK軟體,說句不客氣,根本敗類.
不高興...您與中創公司的可以不要來!!我說算!!!!不信試試!!
04-04-13 02:57
先確定你的信箱能接受12bm的資料,給你!
04-04-14 19:32
请问:关于三菱plc,FX0s系列的一个问题!
当中断源发出中断请求时,plc进入中断服务程序,服务程序的时候是执行几次啊?例如:如下程序,
0   EI
1   LD  X1
2   PLS M10
4   LD  M10
5   ADD K1 D0 D0
12  FEND
13  I101
14  LD M8000
15  ADD K1 D1 D1
22  IRET
23  END
每次接通X1则D0内的数据加1,而D1内的数据则有时加2、有时加3、有时又加4?这是为什么?
04-04-15 16:28
dingdingding
04-04-15 17:10
dingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingding
dingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingding
04-04-15 17:12
dingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingdingding
04-04-15 17:17
04-04-15 17:19
搞什么飞机吗?
04-04-16 08:34
上一页下一页
