CPU Intel PXA270 312 MHz (520 MHz as option)
OS WinCE 5.0
SDRAM 64 MB (128 MB as option)
Flash 128 MB (256 MB as option)
WDT PXA270 internal
Boot Loader 1 MB AMD Flash ROM for boot loader
LCD 10.4" AUO 18-bit TFT LCD SVGA
Touchscreen 4-wire resistive
Graphics Chip Intel 2700G with 32 MB VRAM
COM1 RS-232 by DB-9 conn.
COM2 RS-485/232/422 by phoenix conn., default is RS-485. (S/W configurable)
LAN 1 x 10/100Base-T by RJ-45
USB 2 x USB 1.1 host by type A conn.
SD/MMC 1 x standard slot (support memory and I/O mode)
Audio Line-out by phone jack
Expansion Conn. 50-pin box headers with: SMbus, Mic-in, Line-in,Line-out, 2-wire RS-232, 1 x USB 1.1 host,4 x TTL-level DI, 4 x TTL-level DO
用户应用
用户应用时需要针对相应的系统要求将自己编写的Windows EVC 程序通过网络或者USB等方式加载进入系统运行就可以了。
