首页 PLC论坛 西门子SIEMENS
主题:安装wincc出现的问题[求助]
点击:1175 回复:3
我按照安装步骤先安装了“Simatic_WinCC_V6.0_MS_SQL2000_SP4”和“消息队列服务”。但到安装WINCC V6.0的时候出现了以下问题:
“MS Security Patch is not installed on this system.
For this WinCC Version, the following software is required:
    WindowsXP SP 2 KB319740
Please run the installation of MS-Security Patch from your MS Tools - CD.
Operation of WinCC under Windows XP SP2 has been released for WinCC clients with deactivated firewall only.
You must deactivate the firewall manually.”
我用是的Windows XP系统,请问各位大侠这是我的系统问题吗?我想修复系统,但没见有“MS Security Patch ”的相干选项呀。请高手帮帮我看看是什么问题,如何解决哦?
可以把信息发到我的邮箱:E-main: wuchuidie2004@yahoo.com.cn
急哦!!!!
谢谢!!
07-01-27 22:46
KB319740补丁可以在MSTOOL光盘内找到
07-01-28 11:25
是啊,没有打KB319740补丁
07-01-28 20:42
按照你们的提示,我终于安装好了!真的是非常感谢哦!!
07-01-28 20:53
