安装sql server 2000到100%后,停顿几分钟后出现错误,显示installing software failed
回车后又出现提示,SQL server 2000 hotfix 8.00.05.0568
please reboot you system
setup will cancel now
还要麻烦各位大大指教了,重新装了XP专业版,安装了SQL,添加了信息队列,可是安装WINCC的时候弹出下面文字
MS Security Patch is not installed on this system.
For this WinCC Version, the following software is required:
WindowsXP SP 2 KB319740
Please run the installation of MS-Security Patch from your MS Tools - CD.
Operation of WinCC under Windows XP SP2 has been released for WinCC clients with deactivated firewall only.
You must deactivate the firewall manually.
我以为是杀毒软件的问题,停止病毒监控,还是不能安装。运行msconfig.exe,把启动项目全部去掉,重新启动安装还是不行,我真是没话可说了,不知道各位朋友是怎么安装的,难道也是象我这样难么?
