电路板制作工艺能力及规格(capabilities & specs.)
电路板制作 - 线路板工艺能力及规格
http://www.viafine.com/images/v_line.gif
layers:
1 to 20 layers
base materials:
xpc fr1 fr2 cem1 cem3 , fr4, high tg fr4
base copper thickness:
1oz oz. to 3 oz.
boardthickness:
0.4mm-3.2mm
maximum panel size:
406mm x 610mm
minimum hole diameter:
0.3mm
pth hole tolerance:
0.05mm
aspect ratio:
6:1
blind or buried via:
no
minimum line width:
0.1mm
minimum line spacing:
0.1mm
minimum bonding pitch:
0.127mm
minimum smt pitch:
0.40mm (center to center)
mechanical fabrication:
minimum hole registration tolerance (npth): +/-0.076
minimum hole registration tolerance (pth): +/-0.076mm
minimum pattern registration tolerance: +/-0.076mm
minimum s/m registration tolerance (lpi): +/-0.076mm
minimum annular ring: +/-0.1mm( artwork)
minimum s/m bridge (lpi): 0.1mm
plated gold thickness: 0.01um – 0.025um
immersion gold thickness: 0.025um -- 0.2um
electrical testing:
voltage: 24v - 300v
ontinuity:5 - 100ohms
twist and warp: less than 1% (详细文档:
http://blog.gkong.com/images/file/pdf.gif
一个制板工厂的制板规格书.pdf
此篇文章从博客转发
原文地址:
Http://blog.gkong.com/more.asp?id=88675&Name=zjcsharp
