首页 PLC论坛 PLC论坛
主题:GE PLC 编程软件 C语言开发包
点击:1660 回复:2
plc用c开发,告别梯形图。ge 居然提供了c语言开发包,一直久闻大名。今天终于找到了。有时间研究研究。
下载地址:
http://www.jiyitech.com/2009/0422/ynmdawmdawmduyna.html
ge plc c语言开发包
this manual contains essential information about the construction of c applications for
pacsystems control systems. it is written for the experienced programmer who is
familiar with both the c programming language and with the operation of pacsystems
control systems. for more information about pacsystems, refer to the list of
documents at the end of this chapter.
the pacsystems c programmer’s toolkit contains libraries, utilities, and
documentation required to create c applications for the pacsystems control system.
c blocks are constructed using the ansi c programming language using text editing
and toolkit applications on a personal computer. the c blocks are incorporated into a
pacsystems application program through proficy® machine edition programming
software. using the programming software, c blocks can be called from ladder logic
or invoked by an i/o, module or timed interrupt. in the programming software, use the
add c block feature to insert c blocks.
the pacsystems cpu supports one type of c block, which has the capabilities of
both the series 90-70-type c blocks and c function blocks. the pacsystems cpus
and the pacsystems c toolkit do not support standalone c programs, which is a
feature of the series 90-70.
a pacsystems c block is, by default, limited to 256kbytes in size, provided there is
sufficient plc memory. examples of calculations that might be performed in c blocks
include:
■ ramp/soak profiling
■ lead/lag calculation
■ message generation
■ input selection
■ arithmetic operations
■ pid
■ sorting, moving and copying data
http://www.jiyitech.com/uploadfile/2009/0422/20090422040750227.jpg
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=87359&Name=springal
09-05-11 16:30
看不懂,要顶一下
09-05-11 19:21
