A I 0.4
JC DR
CLR
= Q 4.0
JU END
DR: A I 0.4
L S5T#5S
SP T 0
SET
= Q 4.0
A T 0
JC END
A I 0.4
L S5T#5S
SP T 1
CLR
= Q 4.0
A T 1
JC END
A I 0.4
L S5T#5S
SP T 2
SET
= Q 4.0
A T 2
JC END
A I 0.4
L S5T#5S
SP T 3
CLR
= Q 4.0
A T 3
JC END
A I 0.4
L S5T#5S
SP T 4
SET
= Q 4.0
A T 4
JC END
END: NOP 0
如果屏蔽掉 JU END 语句,打开开关 I 0.4 ,语句顺序执行,所有定时器正常定时,只是关了 I 0.4 ,输出Q 4.0 也为1,一旦加上语句 JU END ,打开开关 I 0.4 时,所有定时器都不工作,输出 Q 4.0 始终为1,这是怎么回事,请哪位高手给指点一下,多谢!
