首页 工控软件 施耐德电气AVEVA软件(Wonderware)
主题:AVEVA宣布增强价值链优化软件产品组合
点击:841 回复:2
AVEVA announces enhancements to Value Chain Optimization software portfolio
AVEVA, a specialist in industrial software, announced enhancements to its Value Chain Optimization  offering to enable customers to eliminate information silos and integrate critical business processes across the operational value chain.
AVEVA’s Value Chain Optimization solution, in recent news, brings together software from across its  portfolio that are intended to  help operators and manufacturers manage their supply chain, operations and process optimization across key industries including Refining, Petrochemicals, Metals, Mining and Materials, Food and Beverage, Consumer Packaged Goods (CPG), Water and Wastewater.
Industrial operations have grown over the last 20 years with poor integration from a legacy of point solutions involving manual data transfer or custom software which has resulted in operational silos across the value chain. AVEVA’s strategy works to help organizations address these challenges and create a collaborative environment instead of business or process silos. In this way the operations lifecycle can be managed in a flexible and connected manner that brings transparency to the decision-making process across the value chain.
AVEVA’s Value Chain Optimization is already deployed by several multinational companies globally:
Abu Dhabi National Oil Company (ADNOC) recently reported benefits of $60-100M USD from integrated production planning
BP Plc has cut crude purchase decision time from two days to less than two hours
New Belgium Brewing has decreased downtime by more than 50% and increased the efficiency of scheduled run time 25% - 30%
Roy Hill worked closely with AVEVA to develop a greenfield iron ore mining site, connecting the entire value chain with industry leading efficiency from pit to port
About AVEVA
AVEVA is a specialist in engineering and industrial software driving digital transformation across the entire asset and operations life cycle of capital-intensive industries.  The company’s engineering, planning and operations, asset performance, and monitoring and control solutions deliver proven results to over 16,000 customers across the globe. Its customers are supported by the largest industrial software ecosystem, including 4,200 partners and 5,700 certified developers.
工业软件专家AVEVA宣布增强其价值链优化产品,以使客户消除信息孤岛并整合整个运营价值链中的关键业务流程。
最近,AVEVA的价值链优化解决方案将其整个产品组合中的软件整合在一起,旨在帮助运营商和制造商管理包括炼油,石化,金属,采矿和材料,食品和制药在内的关键行业的供应链,运营和流程优化。饮料,消费品,水和废水。
在过去的20年中,由于涉及手动数据传输或自定义软件的传统点解决方案的集成不佳,导致了整个价值链中的运营孤岛,工业运营得到了发展。 AVEVA的策略旨在帮助组织应对这些挑战并创建协作环境,而不是业务或流程孤岛。这样,可以以灵活,相互联系的方式管理运营生命周期,从而为整个价值链的决策流程带来透明性。
AVEVA的价值链优化已被全球多家跨国公司部署:
阿布扎比国家石油公司(ADNOC)最近报告综合生产计划可带来6千万到一亿美元的收益
BP公司将原油购买决策时间从两天缩短到不到两小时
New Belgium Brewing已将停机时间减少了50%以上,并将计划运行时间的效率提高了25%-30%
Roy Hill与AVEVA密切合作,开发了一个全新的铁矿石场,将从矿场到港口的整个价值链赋予行业领先的效率
关于AVEVA
AVEVA是工程和工业软件领域的专家,可在资本密集型产业的整个资产和运营生命周期中推动数字化转型。该公司的工程,规划和运营,资产绩效以及监控解决方案为全球超过1.6万个客户提供了可靠的结果。其客户得到最大的工业软件生态系统的支持,其中包括4200个合作伙伴和5700个认证的开发人员。
19-12-13 14:36
AVEVA,工控大佬级别的软件,了解了解就行了。。。。。
19-12-13 15:02
对头,哈哈
19-12-14 00:21
