首页 电脑编程
主题:如何通过(RS-232 TO RS485)转换器把仪器仪表的数据读到计算机
点击:5883 回复:13
自己做比较好,很好的实践机会。祝你成功。
04-07-12 12:23
首先用一种语言做连接,如:VB 。VC ,CB ,DELIPHI 等实现硬件和软件的连接 。然后把数据采集上来后,存在数据库中,如果是初学建议用ACCESS 数据库就够用了 ,如果想导入到EXCEL 中是很方便的事情了。如下附送几句VB 代码供参考 ,请不要见笑,
Dim xlApp As Excel.Application
   Dim xlBook As Excel.Workbook
   Dim xlSheet As Excel.Worksheet
   Dim row_c  As Integer
   Dim col_c As Integer
   Dim i, j As Integer
   Set xlApp = CreateObject("Excel.Application")
   Set xlBook = xlApp.Workbooks.Open("d:\database\proli.xls")
   Set xlSheet = xlBook.Worksheets(1)
     If S_rs.RecordCount < 1 Then
    MsgBox ("no record")
     f_cap = "系统错误!"
     f_cap1 = " 没有数据记录"
     msg1.Show 1, ProList
    Exit Sub
    End If
     S_rs.MoveLast '.MoveLast
     row_c = S_rs.RecordCount
     col_c = S_rs.Fields.Count
     ReDim Fieldlen(col_c)
     S_rs.MoveFirst
     For i = 1 To row_c
     For j = 1 To col_c
     xlSheet.Cells(i + 2, j).Value = S_rs.Fields(j - 1)
     Next j
      If row_c <> 1 Then
      If Not S_rs.EOF Then S_rs.MoveNext
      End If
      Next i
      xlBook.PrintOut     '打印预览
      xlBook.Close SaveChanges:=False
基本上如上几句话就完成了数据库数据导入到EXCEL中存储并打印。
如有何疑问:MSN:renjianwin@hotmail.com
http://www.jetter.cn
04-07-12 22:33
右键、部件、控件、micosoft comm control 6.0即可。
04-07-13 07:56
现有一VBA源程序供你参考。下面是其用户程序的一部分,如果需要请给我联系。
Option Explicit
Dim TXOK As Boolean
Dim ARR() As Byte
Dim CRCCAL, CRCR As Long
Dim Dummy, SBCS, IBYTE  As Integer
Dim BUFFER, OUTBUF As Variant
Dim A%, B%, C%, D%, E!, F!
Private Sub timer1_Timer()
Dim TXI, TXJ, ZH As Integer
Dim FC(4) As Byte
Timer1.Enabled = False
If Minute(Now()) = 0 And BZ = False Then
   BZ = True
   SJ_CC
End If
If Minute(Now()) <> 0 Then
 BZ = False
End If
With Sheets("CJ")
For TXJ = 5 To 27
 ZH = 0
 Select Case TXJ
 Case 5 To 12
  IBYTE = 37
  ZH = Val(.Cells(TXJ, 4).Value)
 Case 16 To 18
  IBYTE = 37
 Case 22 To 23
  IBYTE = 17
 Case 27
  IBYTE = 17
 End Select
 If ZH <> 0 Then
   GoSub OK
 End If
Next TXJ
End With
Timer1.Interval = 500
Timer1.Enabled = True
Exit Sub
OK:
With Sheets("CJ")
FC(0) = ZH
FC(1) = 3
CRCR = 65535
For TXI = 0 To 1
 CRCCAL = FC(TXI) Xor CRCR And 255
 CRCCAL = CRC(CRCCAL)
 CRCR = (CRCR And 65280) / 256
 CRCR = CRCR Xor CRCCAL
Next TXI
FC(2) = (CRCR And 255)
FC(3) = (CRCR And 65280) / 256
OUTBUF = FC
SBCS = 0
TXOK = False
MSComm1.InputLen = 0
MSComm1.RThreshold = IBYTE
MSComm1.InBufferCount = 0
MSComm1.NullDiscard = False
MSComm1.Output = OUTBUF
Timer2.Enabled = False
Timer2.Interval = 500
Timer2.Enabled = True
Do
Dummy = DoEvents()
If TZ = True Then  ''''停止退出
  Exit Sub
End If
If (MSComm1.InBufferCount = IBYTE) Then
  BUFFER = MSComm1.Input
  ARR = BUFFER
  CRCR = 65535
  For TXI = 0 To IBYTE - 3
    CRCCAL = ARR(TXI) Xor CRCR And 255
  Next TXI
  If (ARR(IBYTE - 2) = (CRCR And 255)) Then
    If (ARR(IBYTE - 1) = (CRCR And 65280) / 256) Then
      If ZH = ARR(0) And IBYTE = 37 Then
       .Cells(TXJ, 9).Value = ""
        For TXI = 0 To 6
        A = ARR(TXI * 4 + 3)
        B = ARR(TXI * 4 + 4)
        C = ARR(TXI * 4 + 5)
        D = ARR(TXI * 4 + 6)
        F = READCARD(A, B, C, D, E)
        Select Case TXI
       Case 0
        .Cells(TXJ, 9).Value = Format(E, "#0")
       Case 1
        If Val(.Cells(TXJ, 11).Value) > E + 1 Then
           .Cells(TXJ, 10).Value = Val(.Cells(TXJ, 10).Value) + 1
        End If
         .Cells(TXJ, 11).Value = Format(E, "#0")
         .Cells(TXJ, 5).Value = Val(.Cells(TXJ, 10).Value) * 100000 + Val(.Cells(TXJ, 11).Value)
       Case 3
        .Cells(TXJ, 6).Value = Format(E, "#0.00")
       Case 5
        .Cells(TXJ, 7).Value = Format(E, "#0.00")
       Case 6
        .Cells(TXJ, 8).Value = Format(E, "#0.00")
       End Select
      Next TXI
      Exit Do
     End If
     If ZH = ARR(0) And IBYTE = 17 Then
      .Cells(TXJ, 7).Value = ""
      For TXI = 0 To 2
       Select Case TXI
       Case 0
        .Cells(TXJ, 7).Value = Format(E, "#0")
       Case 1
        End If
       Case 2
       End Select
      Next TXI
      Exit Do
     End If
   End If
 End If
 End If
 If SBCS > 3 Then  ''''通讯失败
   .Cells(TXJ, 6).Value = ""
   .Cells(TXJ, 8).Value = ""
   Exit Do
  End If
 Loop
End With
Return
End Sub
Private Sub timer2_Timer()   ''''重发请求
 SBCS = SBCS + 1
 If SBCS > 3 Then
    Exit Sub
 End If
End Sub
最后修改:2004-7-16 9:24:05
04-07-16 09:15
上一页 上一页
