智能故障诊断专家系统开发平台
史慧,王伟,高戈
北京航天测控技术开发公司 故障诊断技术部 北京 阜成路8号 100037
e-mail:faultdep@casic-amc.com
摘要: 针对故障诊断专家系统实用性与通用性的矛盾,在简要分析专家系统工作原理的基础上,提出了一种以用户为中心的通用性故障诊断专家系统设计方案。将规则推理﹑模糊决策﹑多传感器信息融合算法融为一体,形成一阶梯式故障推理机制;对不同的诊断对象,只要设置好必要知识模块,就可自行生成一专用故障诊断系统,并能自动输出诊断结果。
关键词:专家系统,故障树,规则推理,模糊决策,信息融合,故障诊断。
The General Fault Diagnosis Expert System Development Platform
Shi Hui, Wang Wei and Gao Ge
Fault Diagnosis Technology Department, Beijing Aerospace Measurement & Control Technology Company, Beijing China, 100830. e-mail:faultdep@casic-amc.com
Abstract: In order to overcome contradiction of practicality and generality for fault diagnosis expert System, the design of general fault diagnosis expert system based on user is presented after the expert system is introduced concisely. Rule reasoning﹑fuzzy decision and information fusion algorithm are merged, and the step fault diagnosis method is accomplished; For different object, when necessary knowledge is given, a special fault diagnosis system will be automatically produced, and the diagnosis result will be given.
Keywords: Expert system, Fault tree, Rule reasoning, Fuzzy decision,
Information fusion, Fault diagnosis
阅读全文:智能故障诊断专家系统开发平台
